One of the problems we ran into with Mega-Mini #1 is that there were a number of occasions where we dragged the rear a bit. Subsequent MM's will have three more inches of ground clearance, however...
I do not intend to do any serious rock crawling however we do plan on boondocking and there are times I will want more ground clearance. The Dexter axle has a reputation of being extremely well designed however it reportedly does not do particularly well on washboard.
How to get more height when you want it with a Dexter axle?
Some Times it IS Rocket Science
I gathered a good bit of information on air suspensions and discussed it with my brother-in-law, John, who is a mechanical engineer who has worked in aerospace (jet engines) and automotive, race car design and is an expert with one of the rather esoteric computer programs used for stress analysis. My experience includes failure analysis and non destructive testing including the space shuttle to carnival ride inspection.
To cut to the chase.
The design is finalized and work started on the prototype, the CNC is finished on the bracket attached to the arm and a pair machined out of aluminum. The prototype air shocks will be those used in a Corvette
early design, note final product has only three holes for mounting shock.
Shock support arm attached to axle final design
Machining
Final bracket
This BTW is all being done in John's home work shop
