Standie! or Another Puffin Clone
Postby shopfabricator » Fri Oct 30, 2009 7:47 am
Hi All! I am back for another build. This will be number three.
I have chosen to do another Puffin Clone (6'4" x 8') with a Full Size Bed, Drop Floor and Porta-Potty Closet. I decided to do another because of the e-mails I am still receiving from the first one I sold a year ago on e-bay. This will be a fast build from the notes I have from the first.
Let the fun begin! I will take lots of pics but will only doc the high points. If there is something you would like to see, let me know and I will try to get that too!
...materials can no longer be purchaced at quite those prices mentioned here!
shopfabricator
Images: 138
Postby shopfabricator » Fri Oct 30, 2009 10:16 am
Waitin for a little glue to set so I will take this time to get caught up to present.
I have done All the shopping for the build. Still need to get a mattress, but that can wait.
I'm using the NT 5x8 no floor again.
While a NT I also picked up the trailer jack, the paint to finish the ext. and a 100' extension cord for the elec. $487.43
Finished the Trailer Modification.
Plywood and 1 by from the Big Blue Store. $236.53
Air Conditioner and Frig from Sears. $237.87
Epoxy US Composites $75.00
Windows from local truck cap co. $183.14
Steel Angle and Trim Alum $31.79
Elec Supplies, Stains, Poly, Glue ect. $193.16
Total so far; $1444.92
shopfabricator
Images: 138
Postby shopfabricator » Fri Oct 30, 2009 10:27 am
Floor ready to flip, build drop and seal.
Back to work! :)
shopfabricator
Images: 138
Postby shopfabricator » Fri Oct 30, 2009 2:06 pm
Phones been ringing all day. Seems that everything that had to be ordered has come in today, so I am going to pick up the windows, air and frig. I'll see if I feel like bolting the floor down when I get back.
shopfabricator
Images: 138
Postby grizz » Sat Oct 31, 2009 2:10 am
Fast progress indeed.
Greetings from England.
Rian.
grizz
Images: 29
Postby RAYVILLIAN » Sat Oct 31, 2009 7:29 am
This is just a suggestion/caution after 4 years my drop floor, which was glued and screwed, decide to drop in the the middle of the night while camping. Sooo from now on I plan on running a light angle or just strap iron frame under my drop floors.
having the floor fall out from under your feet a 2 AM is kinda a trill I don't want again.
Gary
111961Image
RAYVILLIAN
Images: 109
Postby shopfabricator » Sat Oct 31, 2009 10:41 am
Dropped Out! :?
Oh No! :shock:
I have always used Tight Bond III for glue and screws.
What glue did you use?
I have sold trailers built this way. :worship:
shopfabricator
Images: 138
Postby mikeschn » Sat Oct 31, 2009 11:19 am
I think Gary drove the screws into the end grain of the plywood. Not sure though, he'll have to confirm that.
Meanwhile, here's one of the dropped floors that I built!
Images: 479
Postby shopfabricator » Sat Oct 31, 2009 12:01 pm
Hey Mike! That looks good!
I frame the outside of the drop sides and screw the bottom to that. It allows a couple more inches of headroom without sacrificing clearance. Also double layer the ply on the main section of the drop to stop spring.
shopfabricator
Images: 138
Postby starleen2 » Sat Oct 31, 2009 4:56 pm
shopfabricator wrote:I'm using the NT 5x8 no floor again.
Dropped floor On a NT/ TSC Type 5X8 - I'll be watching :thinking:
starleen2
5th Teardrop Club
Postby shopfabricator » Sun Nov 01, 2009 10:33 am
Starleen 2: I'll be sure to get lots of pics when I build the door and step. I do my drop floors with a "step over" on the frame. More about this later.
Walls roughed in and standing. Using 3/8" this time on the walls and they really need the remaining internal framing to flatten them out. Almost most looks like I'm trying to build a ball right now.
shopfabricator
Images: 138
Postby shopfabricator » Sun Nov 01, 2009 3:08 pm
Walls are flattening out but there are fight me all the way. :x
As I frame for the each section of roof I really have to push/pull and check the walls for flat.
The front have shows flat while the back has a "bulge".
shopfabricator
Images: 138
Postby shopfabricator » Sun Nov 01, 2009 5:25 pm
Another receipt, misc hardware and supplies. 62.10
Total so far: $1507.02
shopfabricator
Images: 138
Postby mikeschn » Sun Nov 01, 2009 5:31 pm
So how wide is that build? 66", 67", 68"?
Images: 479
Postby shopfabricator » Sun Nov 01, 2009 5:56 pm
Hey Mike: This one will have a Full Size Bed (54 x 75) across the back. I try to keep bed sixes standard so no "special" linen is needed. It will finish 76" wide by 96" long outside.
shopfabricator
Images: 138
