Cutting Out Doors...Router or Jigsaw.....
Postby doctor phreak » Sun Nov 01, 2009 4:08 pm
i wondering what would be better to cut out the door in my wall panel...a router or jigsaw....jigsaw i have , router i do not but can get one from a friend....door is basically a 32 x 36 square with round corners on all 4 sides.....anybody have any step by step pics .....how did you start to cut???? drill a hole and then start??? thanks for the help...
doctor phreak
Postby planovet » Sun Nov 01, 2009 5:03 pm
I know both have been done.
I used a jigsaw for the upper curve in the door but I used a circular saw and a straight edge for the sides and bottom. I just plunge cut with the circular saw. Makes for a straighter cut than a jigsaw, in my humble opinion.
ImageMark (& Cindi)
planovet
The Cat Man
Postby Creamcracker » Sun Nov 01, 2009 5:04 pm
I used a jig saw but if I were to do it again I'd use a router.
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby wannabefree » Sun Nov 01, 2009 5:32 pm
I recommend the jigsaw. You can use a router and get better results, but you can also make a terrible mess of the job. A router doesn't just go where you push it, like a saw does. For how to do it, google "pattern routing." The other consideration is a saw kerf is 1/8 inch wide. The router will make a cut 1/2 inch wide.
One careless move with a powerful router and several inches of sidewall are sawdust. Use a saw.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
R or J
Postby Chris D » Sun Nov 01, 2009 5:34 pm
You could make a jig for the router and use a rub collar. Or as Planovet said plunge cut with a circular saw and then the jig saw. For the radius areas go clockwise it gives ya a better cut :twisted:
Chris d
Chris D
Postby mikeschn » Sun Nov 01, 2009 5:40 pm
I did like Planovet did... Plunged with the skill saw... I had clamped down a piece of wood, and it made a perfectly straight cut. I cleaned up the corners with a jig saw... :thumbsup:
Postby Gage » Sun Nov 01, 2009 7:09 pm
I use both. I drill a 1/4" hole as a start point and then jig saw the door but not on the line. I then come back and use a router with a template to finish. And I end up with a 1/4" gap. It takes a little longer but the end results is what I'm after and have always had a door fit the way it was suppose to. Just the way I do it. It's not the rule.
Image Image Image
Gage
Images: 28
Postby BrwBier » Sun Nov 01, 2009 7:27 pm
If I had it to do over I would not use the cheap jig saw I have. I don't know if a better saw would make a big differance. The inside of the cut always seems to be a smaller radius than the outside. I never considered a jig saw a presion tool so I just buy cheap ones. Maybe thats my mistake.
Brwbier
BrwBier
Images: 100
Postby Ageless » Sun Nov 01, 2009 7:30 pm
As I have both; prefer the router. Jigsaw; even with a fine blade still leaves a rough edge.
Ageless
Postby len19070 » Sun Nov 01, 2009 7:32 pm
I use a router, but my router follows a pattern/jig/template. And I cut the pattern/jig/template with a jig-saw.
I duno what to tell you. :?
Happy Trails
Len
len19070
Images: 24
Postby aggie79 » Sun Nov 01, 2009 8:23 pm
My vote is for a router. I used a template and router with bushing and 1/4" spiral cut carbide bit. It does create a 1/4" clearance between door and opening. My trim will take the gap down to 1/8". If you need a smaller clearance, you can use an adaptor and a 1/8" Rotozip bit.
Template:
Routed door:
Postby Gage » Sun Nov 01, 2009 9:25 pm
Just goes to show you that there are a couple of ways to come up with a quality cut.
I should note that I use a quality 'jig saw' and the blades I use are 32t per inch, straight up and down. You have to take your time. they are easy to burn. I might add. The straight tooth does not rip or splinter and is the main reason I use that blade. It even cuts foam board like butter.
The end result of the way I do it is as follows:
Image Image Image
Gage
Images: 28
Postby doug hodder » Mon Nov 02, 2009 12:45 am
If using a jig saw...the nice hollow ground blades like Gage has shown will give you a superior cut over the stamped ones. Pay the dough and get a good one....you'll be happier. Doug
Postby asianflava » Mon Nov 02, 2009 9:19 am
I cut the door out of the side with both a circular saw and a jigsaw. I love my jigsaw, I think it's the best. I've been using crappy ones all my life until I decided to get a good one. It's like night and day.
asianflava
Postby aggie79 » Mon Nov 02, 2009 9:41 am
I'll second everyone on the use of good jig saw blades and a good jig saw. Personally I like the Bosch jig saw. To get the smoothest cuts, turn the "orbital" setting off.
