TSC fender flaw
TSC fender flaw
Postby regis101 » Sun Nov 01, 2009 9:05 pm
Greetings. I knew this was gonna be a problem. Need to address it before too long. There is only an inch or so of travel before the lip will cut into the tire. In a pinch, I could pull out the lip so that it will go over the sidewall. But that basically ruins the fender. I could cut it off and center it over the tire.
In the end I'd like to have curved fenders that attach to the spring plate so they ride with the wheel. Bummer, huh?
Peace, Regis
Livermore, Ca
Working on Build #2
regis101
Postby Kens » Mon Nov 02, 2009 1:44 pm
Mine is four years old with alot of miles and has never hit the fenders. I have hit pot holes big enough to break beer bottles in the cooler.
Good day every day!
Kens
Images: 26
Postby Lgboro » Mon Nov 02, 2009 6:57 pm
On my TSC (aka. CarryOn) trailer the springs are very stiff and I don't believe the fender will ever hit the tire. I purchased round fenders that fit just like the stock ones and intend to mount them very close to the tire just like the factory ones and hopefully will not have any problems.
Lgboro
Images: 53
Postby regis101 » Tue Nov 03, 2009 12:32 am
I fired off emails to Carry-On about this problem.
I'm going to modify what I have for now. Probably just pull out the lip so that it misses the tread. Small sacrifice for the greater gain.
Besides, this gives me a reason to go with custom fenders. I still like the idea of round fenders that bolt onto the spring plate or u bolt it to the axle so it rides with the wheel.
If they used a 9" wide fender of the same design all would be well as far as a mass produced trailer goes, IMO.
Peace, Regis
Livermore, Ca
Working on Build #2
regis101
Postby toypusher » Tue Nov 03, 2009 5:40 am
toypusher
Images: 324
Postby starleen2 » Tue Nov 03, 2009 8:50 am
ALL the TSC trailers that I have used ALL had the same problem. I even flared out the fenders to keep it from slicing into the tire. Finally I just removed them and built my own. Later it became a selling point to me - i would go to the tractor Supply store and look for the trailer with the worst and or rusted fender and ask for a discount for a defective fender - knowing full well that I intended to remove them later. Usually I could get at least $30.00 - 35.00 off a new trailer
starleen2
5th Teardrop Club
Postby regis101 » Fri Nov 06, 2009 6:47 pm
I used a crescent wrench and pulled out the lip. The horizontal was pretty much at a 45* and it clears the tire nicely. Then I installed gutter edge
along the fender. This will work for a long time.
Peace, Regis
Livermore, Ca
Working on Build #2
regis101
Postby starleen2 » Fri Nov 06, 2009 9:21 pm
Good Solution to the problem :thumbsup:
starleen2
5th Teardrop Club
Postby frank_a » Wed Sep 01, 2010 5:58 am
Plus it looks great!
Frank
Tiny travel trailer - 1979 Sunline Sunspot. Tow vehicles: 2008 Subaru AWD Outback, 2009 GMC 4WD Canyon. For fun: 1923 T bucket hot rod, 1962 Power Cat tunnel hull speed boat. 1974 Dodge Dart waiting for renovation.
frank_a
Images: 34
