Hi All:
Looking for some AC Breaker Panel Advice and AC electrical plan critique; what was your experiance? and heres my AC electrical plan; what you would improve on yours if you were to do it all over again? and on mine outlined below?
Just in process of purchasing parts for a simple electrical system; I'm trying to keep it as simple and straight forward as possible. I'v read though what i could find in electrical secrets. I have a functioning 12V DC System with a 120 ah wet cell, and envision using a plug in style charger (battery minder or my older deep cycle charger). The system consists of ...
- an exterior grade 15 amp marine shore plug in (on the left; drivers; street side)
-15 amp marine breaker, I like the idea of using a marine style 15Amp breaker in a waterproof receptical box; or a simple marine breaker panel
-3 wire 12 ga 300V rated ext cab tire wire (ie exterior extension cord wire);
- wiring in 3 GFIC outlets;
-outlets housed in plastic waterproof outlet boxes with water proof friction fittings for the cab tire wire
- AC power is to be used for heating; powertools; fan; plugging in a portable 12V charger; laptop charger; maybe a AC in the distant future; maybe a microwave. Lights; fans & cooler are all 12V. I can also see adding a solar powered battery charger for my 120 ah wet cell deep cycle marine battery.
I'd connect the breaker to the hot wire (black) and more or less continue the neutral though and make a ground to the frame with green.
What did you do and what did you find worked? what didnt work so well and what would you improve upon if you were to do it again?
Open to suggestions ... Cheers Dave
