Thanks everyone...
The "wild" ends on some of the sub frame are recycled materials, I don't know exactly where I'm going to cut them and at what angle since I haven't really made up a template for that yet. I'm going to screw up a piece of scrap ply and take the saber saw and keep cutting away at the wheel well till I get the "look" I want and can get the wheel out of it. I'd like to make it a pretty tight fit.
Mark...the decking is called "import birch"....has a lot of plies like baltic, but comes 4x8 and is much cheaper and the moisture content was way low. I think it is a poor mans cabinet grade ply, must be meant for me. The sub frame is recycled redwood from my above ground pool deck from some ripped down 4x4's. I sealed all the edges with epoxy and it gets a "mopping" with oil based primer and paint.
2 bits...Yup....I'm single...got tons of trailer parts in the house as well as the GPAM...Gas Pressure Appliance Museum...that pretty much fills up the living room. I was married once, however. I got my camping recliner which is my main chair. Also have a coil of formica in there as well.
Shaun...the plan is to have it come in under 1500#. Steve E's was 1400 and I'm basically modeling his. I'd like to stay under 1500 so I don't need to get the brakes on it.
Kevin....neighbors, what a joke...you should see the crowd that is in there now. Funny part is...no one over there complained when I shot the paint...golly, I wonder why...
Patty....I need to come by and check out some other dimensions. Thanks for the inspiration! Doug
