I bought a new in the box kerosene wick stove . I couldn't resist the price it was $7.99 at the thrift shop . It was going to be used as an emergency source of heat for the house . I live in a rural area that sometimes suffers from power outages . I read the instructions and went online to find out as much as I could . Which wasn't much .
I installed the wicks and fired it up outside for the first time . I ran it at a high temperature to season the metal as the instructions suggested . It used far more fuel than the advertised specs so I thought that I would run it at a cooled temperature to see what kind of a difference that would make . For the second run I brought the stove inside my workshop , in my house . The stove started normally and I set the flame so that it only went half way up the flame holder . I checked the thermometer to record the rise in temperature and closed the door to the workshop . About 20 minutes later I heard a crackling noise coming from the workshop . I opened the door to a room with the top third blocked off with black smoke and 5 foot flames coming from the stove . I went to grab the fire extinguisher attached to the door frame and in the panic could not find it . I ran to the kitchen and got the mini extinguisher and ripped off it's plastic covering . It took the whole can and it didn't look good about half way through but the fire finally went out . There is some minor smoke damage and I have some cleaning to do .
