Keeping sliding doors shut
Postby TomS » Fri Oct 28, 2005 8:34 pm
When I built me cabinets, I spent a lot of time getting my sliding doors just right. They slide really smooth and easy. In fact the slide so damn easy that they slide open when I tow the trailer around my yard.
I need to find a way to keep them closed before we leave for our maiden voyage to Florida in a week. Does anyone have any suggestions?
Thanks,
Tom Swenson
[email protected]
TomS
Postby Nitetimes » Fri Oct 28, 2005 8:40 pm
Duck tape :EXP :EXP 8) :lol: :lol:
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby TomS » Fri Oct 28, 2005 8:42 pm
I have no doubt Duck Tape will work. But, I was hoping to find something a little less tacky (pun inteneded).
Tom Swenson
[email protected]
TomS
Postby madjack » Fri Oct 28, 2005 8:56 pm
...the simplest way I can think of offhand is a hook and eye screen door latch or maybe a barrel bolt or even a small wooden wedge stuck between the sliders or you can check with somebody like Austin Hardware, McMaster Carr, Rockleer or one of the other hardware co's...have you gone into your local hardare or box store and just looked around at the variety of latches and such
madjack 8)
Postby vairman » Fri Oct 28, 2005 8:58 pm
Well you could drill a small hole through the lower tract and put a removable pin in to hold them closed while traving, then pull the pin when you arrive Simple, and not to tacky.... :D
Greg
vairman
Images: 215
Postby madjack » Fri Oct 28, 2005 9:01 pm
vairman wrote:Well you could drill a small hole through the lower tract and put a removable pin in to hold them closed while traving, then pull the pin when you arrive Simple, and not to tacky.... :D
Greg
geeeeez, why didn't I (or Tom) think of that............................... 8)
Postby Boodro » Fri Oct 28, 2005 9:06 pm
Hey Tom , how about magnets ? :thumbsup: If ya have an old dead hardrive around , there are 2 magnets inside you can remove very easy. they very strong too. just a smidgen of glue to hold them on. Just a thought. Maybe velcro , you can buy a roll of it at a fabric shop . :thumbsup:
Ya'll keep cool. 8)
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
Postby TomS » Fri Oct 28, 2005 9:09 pm
Hmmm.. the pin idea sounds workable.
Thanks.
Tom Swenson
[email protected]
TomS
Postby 2paul32 » Fri Oct 28, 2005 9:32 pm
Stick those magnets on the back side of the door and they would be effective but not visible
2paul32
Postby Steve_Cox » Fri Oct 28, 2005 9:39 pm
TomS wrote:Hmmm.. the pin idea sounds workable.
Thanks.
Tom,
I like using cotter pins for stuff like that. Spread the pin a little before you put it in the hole you drilled and it gives it a little tension to keep it in place. Also on the other end is a nice hole to put a small chain or string.
Steve 8)
Steve_Cox
Images: 196
Postby asianflava » Fri Oct 28, 2005 9:42 pm
If the doors overlap, you can drill a hole in both doors and put a pin in the two doors. We had sliding glass doors that was like this.
asianflava
Postby Steve Frederick » Fri Oct 28, 2005 9:47 pm
How about laying a dowel in the tracks of the sliders?
Wrap a bit of tape around the dowels to aid in removing them!
It worked in the movies!! (Thomas Crown Affair) 8)
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby stjohn » Sat Oct 29, 2005 12:50 am
If you have a little up and down play in your doors put a small dowel in the bottum of your track about 1/2 inch from the closed postion,then a small notch in the bottum of your door the notch in the door sets over the dowel when closed when you need to open the door lift the door a 1/4 inch to let it slide open just a thought
Mike
Only he who attempts the ridiculous
Can achieve the impossible
stjohn
Images: 68
Postby asianflava » Sat Oct 29, 2005 12:50 am
asianflava wrote:We had sliding glass doors that was like this.
What kind of grammar is that?
We had sliding glass door that were like this.
asianflava
Postby toypusher » Sat Oct 29, 2005 5:13 am
I used a finger hole that is lined up through both doors and then used a piece a romex that is bent in a U shape. Just put the U shaped wire through the two holes when closed and ready to travel. I had to put a piece of vinyl hose over the wire to make it fit tight. It is the tiny orange thing in this picture at the middle of the sliders.
toypusher
Images: 324
