HF wheel bearing question
Postby RogHodge » Mon Nov 16, 2009 11:53 am
I pulled the hubs off my axle and one side was toast. :cry:
I drove the races out and they appear to be the same. Are they? My hunch is that the bearing and race is the same inner and outer- I thought I should post the question here because I will get better information than the HF call center- if history is any indication. :x
Thanks
For those who would like to have a look I have a build journal and covet your feedback.
http://www.tnttt.com/viewtopic.php?t=33547
RogHodge
Images: 51
Postby madjack » Mon Nov 16, 2009 1:29 pm
Rog, if you look in Steve's collection of info at the top of this section and scroll down, he has compilled a bunch of info on HF bearings...you may find what you want listed there.........
http://tnttt.com/viewtopic.php?t=11178
madjack 8)
Postby BILLYL » Mon Nov 16, 2009 4:02 pm
Rog-
From a similiar experience - the race and the bearing are the same. I found that if you call HF parts - tell them the model of trailer you have and order 2 bearings for each side (they come with the race) And don't forget to order some seals............
Good Luck
"If your children ever find out how lame you really are, they'll
gonna murder you in your sleep...." Frank Zappa
BILLYL
Postby RogHodge » Mon Nov 16, 2009 5:39 pm
Thanks- I saw that before but failed to review it. I notice that you “Need 2 Bearings per wheel 4 per trailer.â€
RogHodge
Images: 51
Postby bobhenry » Mon Nov 16, 2009 6:05 pm
Any farm store will have the bearings and/or even a extra hub. I broke down in full view of a mom and pop farm store and they pulled the entire hub assembly out from under the counter.
Postby Toytaco2 » Mon Nov 16, 2009 6:05 pm
Rog, I don't envy you the HF bearing and seal "circus" that you may have to go through, but, I think all of us who choose to go with that frame must do it. I ended up not even using the el-cheapo Chinese HF bearings and bought all new high quality units at about $20 per bearing (race is included with the bearing) and, yes, 4 sets are required. But, I should be good to go for a long time with proper maintenance. The seals can be tough to find. Here's a link to a post I made which tells the story. http://www.tnttt.com/viewtopic.php?t=30022&highlight=
Hope this helps, and Good Luck,
Mike
Toytaco2
Images: 368
Postby Arne » Mon Nov 16, 2009 6:11 pm
Bearings and seals are universal world wide, like spark plugs.. if you pop out the seal and measure it, any bearing supply place can provide it. It is not 'unusual...
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
