Lawnjockies Build
Lawnjockies Build
Postby Lawnjockey » Tue Nov 24, 2009 4:17 pm
I am converting an ATV trailer I made a few years ago into a teardrop. This isn't going to be a fancy one, just a workman like job. I am going to be using this on my frequent trips between Tennessee, New Mexico and California.
The first thing to do is reweld a couple of funky welds that were cracking. I finished removing the deck today and I wired up a pigtail for plugging in my welder to the house dryer circuit. I am also going to lengthen the trailer by adding to the front and back thus keeping the frame geometry the same.
I have taken a few pictures but I haven't figured out how to post them yet.
Jocko
Lawnjockey
Images: 43
Postby caseydog » Tue Nov 24, 2009 5:57 pm
My build journal is HERE
caseydog
Images: 515
Postby Oasis Maker » Tue Nov 24, 2009 6:17 pm
Lawnjockey, I like the level of commitment to a theme with your profile. One can only imagine what you will name your teardrop?? :lol:
Scott G.
Oasis Maker
Images: 187
Postby caffeine » Tue Nov 24, 2009 11:31 pm
Keep taking those pictures, even if it takes a while to post them. I wish I had taken more.
Eric
A morning without coffee is like sleep.
caffeine
Images: 15
Postby Lawnjockey » Mon Nov 30, 2009 7:17 pm
I pick up my steel for the trailer mods tomorrow. So, if it isn't raining again, I'll start cutting and welding. I'll take more pictures and if I ever figure out how to post them I will.
By the way, I think I got a good price on the steel, $34.00 per 20' of 1/8 wall 2 x 2 square tube.
Jocko
Lawnjockey
Images: 43
Postby Lawnjockey » Tue Dec 01, 2009 5:20 pm
Well I started cutting and welding today after picking up my steel. I am adding 12" forward of the axle and 8" behind. To do this I cut the existing frame square, staggering the cuts. I will insert pieces and weld them in place. Once done I will sister the areas where the inserts are since I am not the greatest welder. I will also add gussetts where appropriate and beef up the tongue. I cut the steel with a Sawsall with a bymetal metal cutting blade. I have a cutoff saw but but that wouldn't help on the existing frame cuts. I was surprised how easy it cut so I used it to cut the inserts too.
I got a late start so I will finish welding tomorrow and start decking.
Jocko
Lawnjockey
Images: 43
Postby Miriam C. » Tue Dec 01, 2009 9:15 pm
Image Jocko. Do you have a digital camera. If so then load the pictures into your computer. Then you will need to resize them and upload them to your galley.
This will help explain:
http://www.mikenchell.com/pichelp.html
Steve Trip has put lots of interesting tools in the Newbies section to help. http://tnttt.com/viewtopic.php?t=11199
Looking forward to the pictures! :thumbsup:
Postby Lawnjockey » Wed Dec 02, 2009 6:41 am
I have a camera and I have been taking pictures. With my computer skills it will probably take me a couple of hours to figure it out but I will do it.
Jocko
Lawnjockey
Images: 43
Postby Lawnjockey » Thu Dec 03, 2009 4:26 pm
After a weather induced break yesterday, I finished up welding the frame up. Well almost, after hauling everything back inside the garage I noticed I had not welded on the tongue jack. Always something. I'll take care of that tomorrow then prep and paint the frame. If I am energetic I'll pick up the decking too.
Jocko
Lawnjockey
Images: 43
Postby Lawnjockey » Sat Dec 05, 2009 11:47 am
Yesterday I picked up the decking, fasteners and template stock. The weather was still not good enough for outside work. This morning I woke up to snow so I lofted the profile in the kitchen while the wife was out shopping. Once the layout was done I cut the template then I put the wall lines down on the kitchen floor. I put my sleeping mat down and tried it out for size. I invited the dog in and the cats gave their approval.
In regards to the actual laying out of the lines for the forward curve I made a large compass out of a batten by drilling two holes the distance of the radius apart. One for a tack and the other for a pencil. It worked great with no flexing. For the aft curve I used a 10' length of 1/2" pvc pipe to form the curve. This allowed me to tweak it with ease until I was happy with the curve. Once happy I ran a pencil line down the edge. Like they say, faster, cheaper, better.
On cutting the template stock I left the line. That means cutting to the outer edge of the line. I used a Bosch jig saw with a metal cutting blade. This gave a finer cut. The next step will be to smooth out any waviness using sandpaper wrapped around a scrap of wood. If I had not left the line the template would be slightly undersized after sanding.
I took more pictures and maybe I might try to figure out how to post them soon.
Jocko
Lawnjockey
Images: 43
Postby teardrop_focus » Sat Dec 05, 2009 11:57 am
You keep threatening to do that. Stop teasing us.
:lol:
Step One: Can you get the pics onto your computer? Let's start there, cause one you can do that, it's pretty easy.
teardrop_focus
Images: 127
Postby Lawnjockey » Sun Dec 06, 2009 6:14 pm
I just finnished painting the trailer after finishing the welding, including the tongue jack this time. I cleared enough space in my garage shop to get it in out of the cold for painting. I cranked up the kerosine heater and promptly set off the smoke alarms.
If the paint sets up in this cold I will deck it tomorrow and varnish the deck.
I clamped up the template of the profile and I did not like it as much as I did when I made it up in the kitchen. The aft curve is fine but the forwar one just isn't right. I think I might just go for a simple 2' radius forward and use the aft curve.
I guess it is time to go shopping for some plywood. I am going to do several coats of varnish on the deck and while I am doing that I may as well be working on the sides.
I will down load some pictures to my computer tomorrow and then give posting them a try.
Jocko
Lawnjockey
Images: 43
Postby Lawnjockey » Mon Dec 07, 2009 7:04 pm
Well I was lazy today and goofed off, went for a run, etc and didn't start work on the TD until 4:00 pm. In the few hours I worked on it I got the deck layed out, cut and clamped into place.
I had a very informative conversation with another member via PM and I will incorporate many of his ideas into my TD. My goal is to keep this as simple as possible and the advice I received will help in that direction.
Tomorrow I will fasten the deck and pick up the plywood for the sides.
Jocko
Lawnjockey
Images: 43
Postby Lawnjockey » Tue Dec 08, 2009 2:09 pm
Photo test
Lawnjockey
Images: 43
Postby caseydog » Tue Dec 08, 2009 2:24 pm
Lawnjockey wrote:Photo test
caseydog
Images: 515
Users browsing this forum: Bing [Bot] and 18 guests
