Modified HF frame question
Postby RogHodge » Wed Nov 25, 2009 10:21 am
I hope you can see/understand what I am thinking here.
The plan is to cut the angle (former bed frame) you see in front down to 3 ft. That way there is another 3 left for the opposite side. Use three bolts through the frame and the angle insert
The two rails are 3 ft each for a total frame length of 6 ft. The spring hanger is placed where it is for wheel placement. As you can see this puts the joint in the frame directly above the front spring bolt. The post-it notes indicate where I will cut the angle and where three bolts will go through the frame and angle to hold it all together.
I believe that it should do the trick when I consider the Andrew ‘ultralight’ frame is a non-frame. I don’t want to/can’t use the regular frame rails inside because they are too jacked up- bent, tweeked, non-true.
So, does this seem like a plausible plan?
For those who would like to have a look I have a build journal and covet your feedback.
http://www.tnttt.com/viewtopic.php?t=33547
RogHodge
Images: 51
Postby clarkbre » Wed Nov 25, 2009 5:11 pm
Are you talking about shortening a 4x8 HF frame to a 4x6 frame? If so, I have written up a whole procedure for doing so. It's posted on schaney's Compactcampingconcepts.com website. Here's the link
http://www.compactcampingconcepts.com/4x6-shortened-frame-procedure.pdf
Brendan
Everett, WA
clarkbre
Postby RogHodge » Sun Dec 06, 2009 12:47 pm
Here is how I resolved this for those who may have taken a look and were curious
Cheers
:thumbsup: Image
Brendan- I got your pdf earlier- it is informative, but I needed to remove a messed up section from the middle portion of the rails- thanks anyway
RogHodge
Images: 51
