Rob
cokebottle10 wrote:You need to be able to jack-knife your trailer to 90 degrees or more whitout it hitting the TV. So if your TV is 6-foot wide at its widest point then I would make the trailer tongue 36-inches (half the width of the TV) plus a few extra inches. Say about 40 inches minimum.
However the longer the trailer the easier it is to back up. Right now I would keep the 54 inches if I could so my old full size ford (over 7 foot wide) and others could pull it.
Thanks,
David.
bve wrote:cokebottle10 wrote:You need to be able to jack-knife your trailer to 90 degrees or more whitout it hitting the TV.
I'm prepared to disagree with this statement as written.
You should be able to park a trailer without going past 45* - if not you should probably reconsider where you are trying to put it.
cokebottle10 wrote:My brother has a 5th wheel trailer with a adjustable hitch. Close to the cab when on the hwy and farther back when parking. He still managed to dent the cab. Not backing up but running forward around a gas station.
