Tire Size
Tire Size
Postby toolbox » Tue Nov 01, 2005 7:59 pm
Well, I know that it is personal choice on what size tire/ rim combo to run, but I would like some advice.
Could a guy notice any difference in ride between these two options -
1. 15"x6" rim with 205/75/R15 tire
or
2. 15"x7" rim with a 225/70/R15 tire
Any suggestions? I am going to be running a 9 inch wide steel fender.
Dave
toolbox
Postby norm perkiss » Tue Nov 01, 2005 8:31 pm
Dave,
I'll jump in. I have 14x6" wheels. My wheel/tire combo barely tucks under the fenders. The tire side wall comes fairly close to the TD body and the rim is only 1/2" away from the idler arm. My fenders are aluminum tread at 10.5" wide.
Just my 2¢ but the 15x7" wheel/tire combintion may be too wide to fit under a 9" fender. Of course I could be completely wrong...
Norm
[img]http://www.tnttt.com/gallery/image.php?image_id=3270[img][/img]
norm perkiss
Images: 62
Postby Gerdo » Tue Nov 01, 2005 8:59 pm
I have 15x6 and 205/70R15 inside a 9" fender. I have about an inch inside and even the sidewall is inside the fender.
Gerdo
Images: 156
Postby madjack » Tue Nov 01, 2005 9:11 pm
norm perkiss wrote:Dave,
Norm
...double ditto's on this one and...
Gerdo
double diitto's on this one also.....
madjack 8)
Postby SteveH » Tue Nov 01, 2005 9:20 pm
Toolbox,
The narrower 15 X 6 wheel with the narrower 75 series tire will ride better. The wider wheel and tire will handle cornering better.
SteveH
SteveH
Images: 42
Postby toolbox » Tue Nov 01, 2005 10:30 pm
Good call on the 6 inch wide rim, I was figuring that would fit better in the 9 inch fender.
Speaking of 15"x6" rims, do anyone know of an online source for this size rim? I am specifically looking for a rim that is chrome and a "mods" style.
I have had no luck in finding this size rim in anything other than white steel.
Thanks much - Dave
toolbox
Postby madjack » Tue Nov 01, 2005 10:46 pm
....40 bucks at tjtrailers
also any redneck trailer supply distributor will have them or try southwest wheel
madjack 8)
Postby asianflava » Wed Nov 02, 2005 1:17 am
225 seems wide to me.
asianflava
Postby bledsoe3 » Wed Nov 02, 2005 3:39 am
Toolbox, I've got 15 X 7 chrome mods on mine. I think the question should be about the offset. I have 3+ inches of clearance from the trailer body. My problem now is finding a fender wide enough to cover the tire. If my wheel was offset and closer to the body, finding a fender would not be a problem. You can see the clearance here. http://www.tnttt.com/gallery/image.php?image_id=2872 and a view of the wheels here. http://www.tnttt.com/gallery/image.php?image_id=1992
bledsoe3
Images: 112
Postby angib » Wed Nov 02, 2005 8:01 am
SteveH wrote:The wider wheel and tire will handle cornering better.
Until it rains. Then you've got a wide tire carrying, at the very most, about one quarter of its design load. Then the word 'aquaplane' suddenly has a meaning and narrow 13" tires start to look real good......
Andrew :twisted:
angib
5000 Club
5000 Club
Images: 231
Postby cracker39 » Wed Nov 02, 2005 8:32 am
Andrew's comment brings to mind my putting wide 14" tires on Corvette rallye rims on a 63 VW bug. Hydroplaning is something I know about...WOW, did I have some scary rides in the rain.
As for Dave's tire/wheel choices, I will leave that to you who have the experience in that area. I'm just sticking with the same size tires/wheels I have on my boat trailer, the standard 13" white spoke wheels with ST175/80 tires. I've had no problems towing it in rain or dry conditions, and they will allow me to keep the fenders I'll build as narrow as possible on an already 5' wide chassis.
Dale
cracker39
Images: 233
Postby Gaston » Wed Nov 02, 2005 7:08 pm
I am thinking a 14 or 15x6 with a 195x50 tire on a chrome american mag. kinda looks like the stock wheel on my cruiser
The difficult we do now... the impossible takes a little longer
Gaston
Images: 98
Postby Chip » Fri Nov 25, 2005 6:42 pm
toolbox,, ya got a few choices of older model autos that had a 4 x 4 bolt pattern,, Chevy Vegas and a few older small general motors had such a wheel,, other than running into a set in the junk yard, ya might have to change out the hubs to a 5 x 4-1/2 or 5x4-3/4. Ebay had some alum racing rims that were 4x4 bolt and either 14 or 15" size but how well they would hold up to street use is anyones guess. good luck on your hunt..
chipper
p/s just found my list,, vega and gm 80 and older,, skylark, starfire, astro and sunbird
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby Steve_Cox » Fri Nov 25, 2005 7:36 pm
Andrew :twisted:
Andrew,
You have mentioned this enough times now that every time I drive in the rain I think of your words, and I haven't even finished my TD yet. :thumbsup:
I know that in the future when I'm pulling my little trailer with the big fat tires I'll be terribly paranoid. I never learned how to hydroplane properly, seems it always involved spinning around and lots of screaming....
Regards,
Steve :lol:
Steve_Cox
Images: 196
Postby kartvines » Fri Nov 25, 2005 8:00 pm
Being I am trying to restore my Scad-A-Bout I wanted to keep the same size tires, the only thing I did was get a slightly beefier tire so I went with a 5.30 X 12 they are the original 4 bolt.
Mike
Image..Image..Image..
Image.
kartvines
Images: 37
