Thanks, I'm having a lot of fun with it. I have a two week road trip beginning in mid January so I have to keep pushing forward.
Jocko
I cut the metal for the wood stove. It is 9" x 9" x 14" with a 3" flu. I ordered the store bought parts, springy thing for the door handle and the air supply disk. I'll weld up the box and then set it on some blocks to figure out how high I want it before I make the legs.
It is a cute little stove like the ones the used to sell for ice fishing shacks. It is going to have an extra heat shield on one side due to the limited clearances in the TD. I also want to make it a bit higher to reduce the chance of bedding brushing up against it. I may have to fabricate some sort of guard to keep the bedding clear.
Lawnjockey wrote:I hope to use a Charlie Noble type cap. However they are very hard to find in 3" so I will probably use an imitation one. It really doesn't matter because I am going put a stuff sack over it when moving to keep soot from blowing all over the interior. I am looking for some scraps of 3" and 4" conduit to make my flashing. I am going to make up some double wall for going through the roof as well as giving an inch from any combustables there. There will be some expermenting along the way and once installed only small fires to start with.
Jocko
Lawnjockey wrote: Herters for $12.00.
Jocko
Lawnjockey wrote:The Dickerson units are nice. Are you talking about the combo exauast/air intakes?
Marine wood stoves are way over priced, for example, look at the Sardine, yikes.
Anything with "marine" on it is grossly over pirced. About 10 years ago I was bumming around China and I still had boats. I found all kinds of good hardware for next to nothing, workboat stuff not foo foo yachty stuff. My bags were a bit heavy on the return flight.
Jocko
