As it sits right now there is 5" side clearence.
]ocko[/img]
BC Dave wrote:Lawnjockey wrote:I hope to use a Charlie Noble type cap. However they are very hard to find in 3" so I will probably use an imitation one. It really doesn't matter because I am going put a stuff sack over it when moving to keep soot from blowing all over the interior. I am looking for some scraps of 3" and 4" conduit to make my flashing. I am going to make up some double wall for going through the roof as well as giving an inch from any combustables there. There will be some expermenting along the way and once installed only small fires to start with.
Jocko
Pipe Stack Idea - Stove idea sounds great; thats what i originally wanted to do too; but couldnt find a stove at the right price / size that i was comfortable with. You sound like you know what your doing; re oxygen, backing, fire safty; CO2 etc.
So I went with a very nice but "spendy" Dickenson Newport 9000 heater (fireplace) ( I went way over budget on this, and I havent told my wife yet ... ) I'm in the process of installing the "ventless fireplace" in a CT,
It uses a double walled chimeny stack (3" outer 1-3/4" inner). You should ba able to set up something similar so theres no worries about oxygen & combustables and it helps keep the stack cool! Look up 3" double walled flex pipe; marine applications. Ide set it up with a longer exaust; then all the vent, cumbustion & gases are self contained in the fire place and stack; your safer that way.
... looking forward to seeing how the stove and TD turn out; your going at a good pace expecially in the cold.
Nice gun rack & bookcases too, (... guns for protection on the road?)
Cheers Dave
mikeschn wrote:
That's a nice looking propane fireplace!!! Does it need 12vdc too?
