Need help attachng wood to metal
Postby dh » Wed Dec 16, 2009 11:13 pm
In the frame tutorial, it talks about putting a wood perimiter around the frame, and attaching the walls to the perimiter.
Does anybody have pictures of this? I would like to do away with the wood torsion box floor, and use a plywood floor. What types of bolts work best for this?
dh
Postby Ageless » Wed Dec 16, 2009 11:19 pm
If you are just using a single sheet of ply for the floor; drill 1/4Hole thru the ply and the frame. Enlarge the holes in the ply, install t-bolts and secure with short capscrews and washers from below.
Ageless
Postby Juneaudave » Wed Dec 16, 2009 11:36 pm
I used trailer deck screws. They are self tapping and seemed to work pretty well.
Juneaudave
Images: 380
Postby madjack » Thu Dec 17, 2009 12:35 am
Juneaudave wrote:I used trailer deck screws. They are self tapping and seemed to work pretty well.
...that is what I use...I have a single sheet ply floor which actually just floats...it is not connected to the frame...it is securely connected to the sides(using 1x1x1/16 Al angle as cleats, w/gorilla glue and screws) which are 3/4" ply and I use the trailer deck screws to connect the sides to the trailer frame...5 per side...works jam-up good...................
madjack 8)
Postby Miriam C. » Thu Dec 17, 2009 10:23 am
I used T-nuts and bolts through the floor. Works great :thumbsup:
Postby dh » Fri Dec 18, 2009 12:48 am
So, I can just attach the walls to the frame, and forgoe the 1x2 perimiter?
dh
Postby Juneaudave » Fri Dec 18, 2009 12:54 am
Did you see the "Wall Attachment Options...Illustrated" Sticky? That might help...
Juneaudave
Images: 380
Postby Ageless » Fri Dec 18, 2009 1:53 am
1 X 2 perimeter will allow insulating the floor. If you ain't gonna get in chilly conditions; your mattress will supply all the insulation you need
Ageless
