Chris C wrote:Foam brushes are an excellent way to apply Spar-Var...............but then so is a spray gun....................it won't leave any brush marks or bits of foam behind.
WarPony wrote:Doug Hodder gave me a tip......... use a foam roller to put on the product and use a foam brush to drag out the bubbles left behind. It worked great!! I tell you what, you can REALLY lay down the spar with a roller!!!
toypusher wrote:I use a good quality brush, wet edge, and fine touch. Don't seem to get brush marks. Practice a little and you can get the hang of it (feather in).
Just how I do it!
