Door knob/latch
Door knob/latch
Postby Lawnjockey » Sun Dec 20, 2009 6:28 pm
What should I be looking for in a door knob/latch and where should I get it?
Thanks
Jocko
Lawnjockey
Images: 43
Postby prohandyman » Sun Dec 20, 2009 6:34 pm
Jocko
On my last build I wanted to use something different than the sometimes "obligatory Model A latch", so I built up the door and jamb to accept a regular house lockset
Dan
prohandyman
Images: 785
Postby planovet » Sun Dec 20, 2009 7:39 pm
I like our latches because of the dead bolt and the fact that they lie almost flush with the door. Nothing sticks out. The only bad thing is you need doors at least 1 1/4" thick.
ImageMark (& Cindi)
planovet
The Cat Man
Postby bbarry » Sun Dec 20, 2009 7:46 pm
I used the L handle shown below:
with the lockset that has an interior thumb latch:
I don't have a good shot of them on up close. They worked out great for a 1" thick wall. Just a small shim plate on the inside behind the lock gave me the perfect "ker-thunk" close.
I think you can get them from any Red Neck Trailer location. I ordered mine from http://www.tjtrailers.com/store/door-accessories.html. If you use something like this, remember to get one right-hand lockset and one left hand. The handles are all the same.
Brad
Brad
Jack of all trades, master of none.
Kampster build thread
bbarry
Images: 159
Postby Jst83 » Mon Dec 21, 2009 1:55 am
As Dan did I also went with the standard house door knob and have had no troubles with it. I'm planning on the same with my present build
Jst83
Images: 215
Postby Lawnjockey » Mon Dec 21, 2009 8:15 am
My door is 3/4'" thick so a regular door knob won't work. I also have a 3/4" door stop so I figure I will have to put a 3/4" block on the door where the handle goes thus the door is effectively 1 1/2 inches thick where the latch is mounted. Is that a thickness that the lever type latches sold by the TD parts suppliers will work on?
Jocko
Lawnjockey
Images: 43
Postby prohandyman » Mon Dec 21, 2009 9:19 am
The lever types can be used on any thickness, since the shaft is left extra long and you cut it to your length after installing
Dan
prohandyman
Images: 785
Postby Lawnjockey » Mon Dec 21, 2009 11:01 am
Thanks, is there any brand or type to look for or stay away from?
Jocko
Lawnjockey
Images: 43
Postby b.bodemer » Mon Dec 21, 2009 6:48 pm
Like Dan I went with a regular door set, just picked a different looking style knob. Easy to find two with the same code.
Used a cool tool to cut everything just right!
Barb
b.bodemer
Images: 328
Postby S. Heisley » Mon Dec 21, 2009 8:44 pm
Jocko, if you have a Lowes nearby, take a look there. I saw a security screen and storm door latch and dead bolt lock set there that looked good and would work on a 3/4" to 1-1/4" thick door. It was nice looking; but, if I remember correctly, the set was $44.
Postby Lawnjockey » Mon Dec 21, 2009 9:03 pm
Thanks Sharon, I'll do that.
Jocko
Lawnjockey
Images: 43
Postby aggie79 » Mon Dec 21, 2009 9:36 pm
S. Heisley wrote:Jocko, if you have a Lowes nearby, take a look there. I saw a security screen and storm door latch and dead bolt lock set there that looked good and would work on a 3/4" to 1-1/4" thick door. It was nice looking; but, if I remember correctly, the set was $44.
Like Sharon pointed out, I'll be using a mortise-type storm door lockset.
I bought mine online but they are available at the blue box.
Postby Mauleskinner » Mon Dec 21, 2009 10:21 pm
Mauleskinner
Postby nevadatear » Mon Dec 21, 2009 10:48 pm
the type brad refers to are also available from Grant Whipp on his li'l bear website. That's where I got mine.
nevadatear
Images: 171
Postby S. Heisley » Tue Dec 22, 2009 11:34 am
That's it! Just like Aggie79's picture! :yes:
