alftinc wrote:Has anyone used CPES under regular Epoxy??
alftinc wrote:Does CPES build up to a shiny finish after more than 2 coats?
alftinc wrote:I was thinking of using one coat of CPES to absorb into the wood and then finishing with Epoxy then Varnish. This if for the walls and roof and not under the floor, where I have already sealed with Asphalt Emulsion.
alftinc wrote:Has anyone used CPES under regular Epoxy?? Does CPES build up to a shiny finish after more than 2 coats? I was thinking of using one coat of CPES to absorb into the wood and then finishing with Epoxy then Varnish. This if for the walls and roof and not under the floor, where I have already sealed with Asphalt Emulsion.
Steve_Cox wrote: I'm sure Andrews quote....was meant as a tongue in cheek comment
Steve Smith wrote:On new plywood the coverage will likely be 200 square feet per gallon, maybe even more than that since you are using high-quality plywood, and not stabilizing old wood. You may even see 400 square feet per gallon...it really depends on the wood.
There will inevitably be condensation behind that aluminum skin, and water will accumulate there, and open the door to rot issues. Clear Penetrating Epoxy Sealer isn't the total answer, but for thirty years it has helped wood resist deterioration from Small Life.
I recently invented something new, and today if I was building what you are (or most anything of wood that sees weather or condensation), I would use the Wood Vitality www.fresher-treated.com first, and Clear Penetrating Epoxy Sealer second.
I understand about the sticker-shock...most of the Smith & Company customers are restoring somewhat deteriorated wood, and coverage really does range down to 20 square feet per gallon or even less, but when looking at the replacement cost of fascia or window-frames it is still a practical solution.
I hope that helps put things in perspective...
The two-gallon kit costs $100.00 delivered anywhere in the 48 states.
Endo wrote:Kerry
The price is listed on the webpage.The two-gallon kit costs $100.00 delivered anywhere in the 48 states.
