deadsoft trim
deadsoft trim
Postby bubba8814 » Tue Nov 24, 2009 1:19 am
anyone know where i get the deadsoft trim used for the gally door
SUPERSTREET88.... IF YOU LIFT,,,YOU LOSE
bubba8814
Postby Gage » Tue Nov 24, 2009 1:23 am
Try Lil' Bear. He has everything you need to trim out a teardrop.
http://www.lilbear.teardrops.net/parts.html#molding
Image Image Image
Gage
Images: 28
Postby So-Cal Teardrops » Tue Nov 24, 2009 11:53 am
We some of the same and a few that we have extruded for us.
http://www.socalteardrops.com/trimmolding.html
So-Cal Teardrops
Postby madjack » Tue Nov 24, 2009 11:58 am
Gabe, I was going to add y'alls name to the list but ya beat me to it...you can also check with your local RV dealer to see what they may have in stock or you can use annealing to make box store angle/channel dead soft as well...............
madjack 8)
dead soft aluminum??
Postby John Samarin » Thu Dec 31, 2009 9:44 pm
How do ya all bend this dead soft drip rail, around 15" & 4" and 8 inch curve??
signed; The New Grasshopper on the block
John Samarin
I was told!
Postby John Samarin » Thu Dec 31, 2009 9:51 pm
I was told by So. Cal Teardrops, it was easy$$%&&^**((*@# yeah right!!
What's the trick? I ruined 2 sticks of drip rail, not cheap!! Will not dispair and will try again w/ help from fellow TD wizards. :roll: :thinking: 8)
John Samarin
Re: I was told!
Postby Gage » Thu Dec 31, 2009 10:29 pm
John Samarin wrote:I was told by So. Cal Teardrops, it was easy$$%&&^**((*@# yeah right!!
It is easy, just do it at an inch at a time. Don't be in a hurry to get it in the shape you want. I use a precut piece of wood as a jig to help with the forming.
Image Image Image
Gage
Images: 28
Postby doug hodder » Thu Dec 31, 2009 10:44 pm
Like Gage says....use a template to do it. Cut the profile you want, attach it to your bench, clamp/screw down 1 end of the molding, then work the rest of it across your shape. A piece of wood and a mallet works well to dolly it to the shape you want. On a really tight radius, the mounting flange will want to curl as it is having to do a lot of stretching, so watch that. Just my experience with it all. Doug
What!!
Postby John Samarin » Thu Dec 31, 2009 10:46 pm
What do mean don't hurry! Me hurry? I don't hurry! I've never hurried! I might go a little fast sometimes!, and get antsy, but hurry, NEVER!! 8)
John Samarin
Ok!
Postby John Samarin » Thu Dec 31, 2009 10:48 pm
THANKS "GUY'S" & HAPPY NEW YEAR
John Samarin
