SIERRA NOMAD 1/31/11 did the mag. rack
Postby Gage » Sun Jan 03, 2010 7:15 pm
doug hodder wrote: ..............I'd like to not have to drop it any lower, but can on the flexiride, maybe 1 spline. Doug
How about you pull the wheels and put it on a couple dollies. :thinking: And by the way, it's looking good. :thumbsup:
Image Image Image
Gage
Images: 28
Postby rainjer » Sun Jan 03, 2010 7:19 pm
Wow Doug, it is looking awesome.
Jeremy
rainjer
King Koleman
Images: 11
Postby doug hodder » Sun Jan 03, 2010 7:23 pm
Gage...I can get it out...I'm just wanting to make sure I can run it in and out of the garage at will without having to do a lot of work on it. When I finish up a trailer, they typically get prime spot in the garage for a year or so. After that, it's in the smaller storage garage....after that, it's off to someone elses garage.....Doug
PS...I would have loved to have that stove/oven combo in aqua that was in your Santa Fe!
Postby Gage » Sun Jan 03, 2010 7:53 pm
doug hodder wrote:PS...I would have loved to have that stove/oven combo in aqua that was in your Santa Fe!
Tell me about it. Marianne won't let me have them back. You can get a 'Tonka' aqua/turquoise shaker paint that is real close. That's what I'm painting my ice box and stove top with. I'm making a stove top hood that will also be painted to match.
Image Image Image
Gage
Images: 28
Cuzin' "Nomad" is born........
Postby Steve E » Sun Jan 03, 2010 7:56 pm
We are mighty proud to be related.......Cuzin' "Nomad" is pretty fine lookin' little standy.....The wheel wells look super!!!! Great profile and inside is beeeeuuuuuutiiiifulllll................Congrats.......Ya Did It!!!! :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup:
Patty
Steve E
Postby S. Heisley » Sun Jan 03, 2010 8:41 pm
It looks like you had a lot of fun this weekend, Doug. I'll bet that painting that speckled wall was a blast! :thumbsup:
You're movin' on that thing!
Postby Micro469 » Sun Jan 03, 2010 9:28 pm
doug hodder wrote:Gage...I can get it out...I'm just wanting to make sure I can run it in and out of the garage at will without having to do a lot of work on it. When I finish up a trailer, they typically get prime spot in the garage for a year or so. After that, it's in the smaller storage garage....after that, it's off to someone elses garage.....Doug
Ye can also just take a little air out of the tires..... You do have a compressor don't you??? ;)
John
Micro469
Images: 382
Postby bdosborn » Sun Jan 03, 2010 9:41 pm
Doug,
Changing the angle on the flexiride is pretty easy. You just need a BAW (Big A$$ Wrench) to get a 1-1/4" bolt off. The first time is pretty tough because they really torque them down from the factory. Mine was settling a little so I raised it an 1" or so.
Images: 806
Postby doug hodder » Sun Jan 03, 2010 9:47 pm
Bruce....so how much lift/drop do you get per spline on the shaft? Any thoughts? Thanks. Doug
Postby bdosborn » Sun Jan 03, 2010 10:13 pm
Doug,
One spline isn't very much. I probably moved it about 5 to 6 splines to change it an inch. I used a level to mark the position of the arm on the frame and then I drew a mark an inch below that. I lined the arm up with the lower mark when I put it back on. One thing I noticed on our trailer is that it wasn't level from side-to-side because there's more weight on on side than the other. The flexiride made it easy to level the trailer.
Images: 806
Postby doug hodder » Sun Jan 03, 2010 10:29 pm
Thanks for the info. That's what I needed to know. Doug
Postby Dave A » Mon Jan 04, 2010 12:02 pm
Hey Doug, looki'n GREAT. I can't wait to see it in person.
Dave
Dave A
Postby angib » Mon Jan 04, 2010 12:28 pm
doug hodder wrote:so how much lift/drop do you get per spline on the shaft?
The Flexiride drawings show 6 degrees per spline and with a 4.5" arm that gives a shade under 0.5" movement per spline when the arm is nearly horizontal - obviously it's less as the arm moves away from horizontal, down to 0.3" per spline with the arm at 45 deg.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby doug hodder » Mon Jan 04, 2010 1:31 pm
Thanks Andrew! I"m at 0 degrees now, once it squats down on the axle in it's finished weight, I can maybe get by with a minor adjustment. Doug
Ouside stripe?
Postby John T. Hodgen » Mon Jan 04, 2010 2:04 pm
Hey Doug,
Since you are calling it "the Nomad" and it has a color of a '55-'56
Chevy, what kind of exterior custom job are you thinking? IMO a
'57 aluminum panel(paint) as on the car fins with the stripe resembling the cars trim to the front wood be Kool!! And have Nomad flow cut out of stainless and polished above the stripe in front by the end of the (trim)But then you'd have to have a '55/'57 chevy to pull it with but so cool and your boat would look great behind that Chevy too!!
Til later by the fire--John T. & Linda
8) :) :lol:
John T. Hodgen
