DO table
Postby rmcelroy » Tue Dec 05, 2006 11:46 am
Right now I'm using the pan portion of a cheap disposable grill from wally world to hold the charcoal. I'm looking to get it all off the ground.
I like the sound of the ceramic tiles to use with on-site picnic tables, I'll probably go that route at least on a temp basis. I saw one regular table yesterday that weighed 27 pounds-maybe thats the way to go.
I guess I'll just have to go out and camp and cook to figure it out (darn)
Mc
Wheather you think you can or you think you can't, your right.
Henry Ford
rmcelroy
Images: 27
Postby apratt » Tue Dec 05, 2006 11:52 am
rmcelroy wrote:Right now I'm using the pan portion of a cheap disposable grill from wally world to hold the charcoal. I'm looking to get it all off the ground.
Mc
That was my problem, I had my DO for 3 years just could not get myself to cook on the ground. I wanted it at table height, that was when I came across the Volcano. Yes go camping a few times then you can decide what is right for you. :thumbsup:
I asked my wife I wanted one of them DO table (posted above) for xmas. :worship:
Arthur,
ASL spoken here
apratt
Images: 16
Postby Gaston » Tue Dec 05, 2006 12:10 pm
Be real careful cooking on tiles. I tried it sitting on a plywood box using cement board tile backer and almost charred a hole thru the plywood. Tile and metals are "burn proof" BUT they are not insulating materials and will transfer the heat to the surfaces under them. I now use the tile board sitting on 4 small bricks and I set the oven and coals in a metal pan. Burning tables in a campground ain't cool :thinking:
The difficult we do now... the impossible takes a little longer
Gaston
Images: 98
Postby rmcelroy » Tue Dec 05, 2006 3:30 pm
Mmmmmm, good to know Gaston. I would have done the same thing-didn't know the temps would be that high.
Mc
Henry Ford
rmcelroy
Images: 27
Postby 8 » Tue Jan 12, 2010 10:36 pm
I just had a thought. (did you smell something burning?)
Do you think an old satellite dish (the small type used by Dish Network) would work as a surface to make a small DO table?
There may be issues with the paint burning off at first. I'm not sure if they are steel or aluminum. I have an old one in the garage I might try. I'm not sure if the diameter is right to to set it on top of a (clean) metal garbage can. To use on a table, make some type of ring to set it on.
It's not fun and games until someone loses an eye.
Visit my blog ... http://www.64ox.com
Postby Prem » Wed Jan 13, 2010 12:56 am
Old, heavy-duty, typing table. $1.00
http://www.tnttt.com/viewtopic.php?t=34340
Prem
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby bobhenry » Wed Jan 13, 2010 3:05 am
I found a projection table tossed out in the trash worked great and light.
I don't know where the stainless steel pan came from but I held the coals well and acted as a wind break.
Your smokey joe Jr. grill make an excellent wind break for a 12" D.O. and helps to concentrate heat in cold weather.
Yes I knuckled under and moved up a bit !
Postby Cliffmeister2000 » Mon Jan 18, 2010 9:15 pm
I use a metal oil change pan as was suggested above, but I don't flip it. It acts as a windscreen too.
At home, I set the oil pan on a stove grate that has about 1-1/2" legs, and that sits on a slate table. Seems to work well. When camping, Ijust put the pan on the ground. Looks pretty much like this one, 'cause it is. I took this picture before Iactually used it.
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby Catoosa Grani » Mon Jan 18, 2010 10:32 pm
We also use the metal oil pans and have for quite some time. They do work great, and we also use them right side up.
Grani
Catoosa Grani
Images: 86
Postby Joanne » Tue Jan 19, 2010 12:35 am
8 wrote:I just had a thought. (did you smell something burning?)
You mean one like this?
I'm not sure if an aluminum dish will stand up to the heat. I made that one because it looked like fun.
I like to make tables out of plow disks. They work really well. I make it so the windscreen will come off and the legs screw off. It packs down nice and small.
Joanne
New! My Camp Cooking Forum
Project Desert Dawg website
Universal Health Care
Joanne
Queen of Cast Iron
Postby TENNJIM » Tue Jan 19, 2010 3:19 pm
If the metal pan or plate is strong enough to support the Dutch Oven, short legs can be accomplished on those upright pans/plates by drilling four holes and using 2.5", 3", 4", or 5" bolts or whatever with two washers and two jam-nuts per bolt. The bolt-head will act as the bottom of the support. On the threaded-end, the arrangement would be jam-nut, washer, pan bottom, washer, jam-nut. This would elevate the pan off a table or the ground and offer screw-on, screw-off legs since finger tight is good enough.
8)
Jim B / Utah
TENNJIM
Palladium Donating Member
Images: 35
Postby 8 » Mon Feb 01, 2010 12:51 pm
Exactly what I was thinking Joanne. Except mine says "Hughes" instead of "Sony." And I just looked at it and it's an oval offset dish and not a perfect circle. It still might work.
Postby jdarkoregon » Tue Feb 02, 2010 12:33 am
Joanne & 8
Can you show how you attach the legs to your dish? Are they removable or fixed?
I use an oil pan which works well, but I have lots of access to old dishes
John
Innovation is essential
The world can be better
jdarkoregon
Images: 47
Postby bc toys » Tue Feb 02, 2010 7:08 pm
The project I just finished. Aluminum frame table to be light weight, stainless steel top for dutch oven cooking.
bc toys
Images: 42
Postby Joanne » Mon Feb 08, 2010 12:28 am
jdarkoregon wrote:Joanne & 8
John
Hi John,
Take a look at this link. It has complete instructions on how I put it together.
http://camp-cook.com/forum/viewtopic.php?t=801
Joanne
Joanne
Queen of Cast Iron
Return to Cast Iron
