A little Construction Humor
Postby Gage » Thu Jan 28, 2010 2:00 am
I just don't understand. I measured it once and cut it twice and still have a big gap. Maybe I was suppose to measure it twice and only cut it once. You think? I'm so confused. :o
1946 KIT rebuild is HERE
Image Image Image
Gage
Images: 28
Postby PaulC » Thu Jan 28, 2010 2:44 am
:lol: :lol: Maybe some trim will hide it ;)
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby emiller » Thu Jan 28, 2010 6:26 am
Wow looking great. :thumbsup:
emiller
Images: 157
Postby ajricher » Thu Jan 28, 2010 7:35 am
Gage, shift the hinges a bit upward and that will look a lot better...
or, if you insist on a "fix", :) then pull the door and cover the edges with a run of the laminate that you used for the surface. A bit of sanding of the edges to smooth and Bob's yer uncle.
Barring that rip the door a bit smaller and add 4 strips of a nice contrasting hardwood and call it a design feature!
All in all, a trivial issue. That is coming along very nicely.
Alan
ajricher
Re: A little Construction Humor
Postby Classic Finn » Thu Jan 28, 2010 8:51 am
Gage wrote:I just don't understand. I measured it once and cut it twice and still have a big gap. Maybe I was suppose to measure it twice and only cut it once. You think? I'm so confused. :o
Gage, Did you use inches or millimeters? :lol: ;) Id say install trim on it, best way to cover up a mistake. :thumbsup: Other than that Gage you are a true craftsman that tear is looking very nice. :applause: :applause:
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Cliffmeister2000 » Thu Jan 28, 2010 12:31 pm
ajricher wrote: pull the door and cover the edges with a run of the laminate that you used for the surface. A bit of sanding of the edges to smooth and Bob's yer uncle.
Bob's yer uncle?!? :lol:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby steve smoot » Thu Jan 28, 2010 12:40 pm
it looks good to me, I would just take another saw cut off the bottom, so all four sides look the same.... :thumbsup:
and, don't tell anyone... :applause:
I am not a complete idiot, some parts are missing...
steve smoot
Images: 62
Postby Arne » Thu Jan 28, 2010 12:45 pm
I used to convert my vans to campers.. Once, I measured a window and cut out the rectangle in the side of the van, only to discover, to my dismay, that the window had rounded corners...
Had to make an unnecessary wooden frame to put over the hole to accommodate the window... crap happens.... and then you fix it.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby ajricher » Thu Jan 28, 2010 1:02 pm
Bob's yer uncle?!?
An English expression, relating back to nepotism in the Prime Minister's office in Edwardian times.
From phrases.org.uk:
Another interpretation is that it derives from the supposed nepotism of Lord Salisbury. Piers Brendon, in Eminent Edwardians, 1979, writes:
"... in 1887, Balfour was unexpectedly promoted to the vital front line post of Chief Secretary for Ireland by his uncle Robert, Lord Salisbury."
The expression has degenerated to meaning "and there you have it" or similar task completers.
Alan
ajricher
Postby PapaGene » Thu Jan 28, 2010 5:15 pm
Gage, there is no such thing as mistakes in woodworking, only "design changes". :o :)
Gene
PapaGene
Images: 20
Postby Larwyn » Thu Jan 28, 2010 6:57 pm
Looks more like a calculated clearance to allow for the proper operation of the hinged aperture cover than an accidental gap to me............. :lol:
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
Postby Gage » Thu Jan 28, 2010 7:11 pm
Looks like the cat is out of the hat so here's the rest of the story. Yes the gap was planned. At first I was going to put a red light behind the door as an accent light at night but got to thinking that it's my sisters teardrop so I'm going to add some decorative molding around the door instead. ;)
Image Image Image
Gage
Images: 28
Postby Miriam C. » Thu Jan 28, 2010 7:35 pm
Gage wrote:Looks like the cat is out of the hat so here's the rest of the story. Yes the gap was planned. At first I was going to put a red light behind the door as an accent light at night but got to thinking that it's my sisters teardrop so I'm going to add some decorative molding around the door instead. ;)
:thinking: I wonder if you can get a rope light that small. Maybe one of the places that cater to auto detailing. Could serve as a good night light.
LOL
Postby Kelleyaynn » Thu Jan 28, 2010 7:36 pm
A tear for the red-light district!!!! :lol:
For "mobile services" I presume.....
Kelleyaynn
Postby Ageless » Thu Jan 28, 2010 7:51 pm
The revised revision of the revised revision revised?
Ageless
