d_lairson wrote:Could there be a problem running a hose filled with propane next to electrical wiring?
planovet wrote:d_lairson wrote:Could there be a problem running a hose filled with propane next to electrical wiring?
Depends on your definition of "problem":
Seriously, I would keep the lines external and not run them in the walls. If you aren't sure, have a professional do it for you.
And if you used threaded pipe; never, ever use teflon tape for the fittings!!!
Ageless wrote:And if you used threaded pipe; never, ever use teflon tape for the fittings!!!
Dale M. wrote:Ageless wrote:And if you used threaded pipe; never, ever use teflon tape for the fittings!!!
Why not........
It's a inert product acceptably for all "gas" and "liquid" tapered pipe fittings...
http://en.wikipedia.org/wiki/Thread_seal_tape
It serves no purpose when used on straight threads like in the CGA510 (POL) connector at propane tank and with fittings using ferrules or flairs....
Guess nobody ever told the propane technician who installed the 250 gallon tank and new regulator and fixed a leak at my forced air heater in home we purchases last yer....
Dale
