And if you used threaded pipe; never, ever use teflon tape for the fittings!!!
When I called the propane company and was asking all my questions about installation, they told me to use teflon tape and then put gas pipe dope over it.
GreatPumpkin wrote:Technically, standard teflon tape (white) should not be used for gas fittings. In some parts of the country, it is a code violation. There is a yellow teflon tape available for tapered pipe threads, but let me clarify what tapered threads are vs flared fittings...
Tapered is the standard thread (NPT or National Pipe Thread) on galvanized or black iron pipe. This is where you would typically use Teflon tape (of the correct color).
S. Heisley wrote:Ageless wrote:And if you used threaded pipe; never, ever use teflon tape for the fittings!!!
Basically (code violations aside) there is no difference whether the tape is white, yellow, green, red..... Its only the pigment used in tape manufacturer ..... The chemical and physical properties of tape is the same...
Dale
Perhaps the propane company suggested the use of dope on sealer to account for potentially improperly applied tape because they assume the phone question is coming from a novice?
Steve_Cox wrote:KEY-TITE my favorite gas line sealant.
This viscous sealant cannot be equaled for leak proof sealing of threaded, flanged and gasket joints. Use Key-Tite® in flow lines for hot and cold water, aqueous solutions, low pressure steam slurries, natural and manufactured gases, compressed air, filled products*, dilute acids and caustics, and alcohols. Key-Tite® is dark green and consists of vegetable and mineral oils and prime and extender pigments, plus an anti-oxidant. Key-Tite® contains no lead or other toxic ingredients, and will not affect the taste or color of water or any other potable liquid.
