Trim Moulding found in Europe
Postby Classic Finn » Sat Jan 30, 2010 1:28 pm
Found a company in Europe that sells Trim Moulding. Soft for easy bending. Website is here http://tacoeurope.com/cat--Trim-Moulding--trim.html They have other interesting parts as well. ;)
A50-0273
Light Weight aluminum edge trim for tight radius bending. 6000 prime grade aluminum grade alloy.
Another term for it is - Transom Trim
A50-0273 Product Detail
Bulk Length Height Width Screws Finish
A50-0273TAL12D 12’ 5/8" 1/4" #5 TAL
Drilled and countersunk on 6" centers
Also this: http://tacoeurope.com/cat--Rigid-Vinyl- ... lding.html
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Ageless » Sat Jan 30, 2010 1:46 pm
Ah yes, 6000 series AL; referred to high formabilty in aircraft.
Ageless
Postby Classic Finn » Sat Jan 30, 2010 4:11 pm
Ageless wrote:Ah yes, 6000 series AL; referred to high formabilty in aircraft.
So :o :shock: Is this good material to use then? What do I know :lol: :lol:
From that website is that other moulding good for use ?
Classic Finn
Images: 146
Postby Ageless » Sat Jan 30, 2010 4:23 pm
Yep; at Boeing; used aa lot with forming compound contours as it is 'soft' and won't crack. Then it can be heat-treated to a T6 condition
Ageless
Postby Classic Finn » Sat Jan 30, 2010 5:16 pm
Ageless wrote:Yep; at Boeing; used aa lot with forming compound contours as it is 'soft' and won't crack. Then it can be heat-treated to a T6 condition
Well All Beeeee. Learned somthing again in my high age :lol: :lol:
Classic Finn
Images: 146
Postby Classic Finn » Sun Jan 31, 2010 3:31 pm
Ive been diggin deeper into this company via the website. And again I found this.
http://tacoeurope.com/item--13-16-x-9-1 ... -0326.html
Sooo is this also the soft bendable moulding. All that says 6000? If so what luck I have in finding this site. :D :D
However what is the normal size corner moulding you folks use there in the States? Is this too big maybe? :thinking:
For those of you that are on this side of the Atlantic here is the contact info for the moulding and all.
Taco Europe by Zwaardvis
Van leeuwenhoekweg 22
5482 TK Schijndel
The Netherlands
+31 73 65 80 059 · Fax:+31 73 54 32 321
Classic Finn
Images: 146
