I've done it both ways. Although the one I built on the work bench and then installed is a slider, I wouldn't think it really maters. It's all in what is easier for you. With the KIT I'm rebuilding, I'm building the galley in place. The thing about building it in place, you have to think ahead because there is very little room for mistakes.dh wrote:Is there any advantage to building the gally/cabinets as a seperate unit and installing? It seems easier to me to put cleats on the walls and install one board at a time.
Gage wrote:I've done it both ways. Although the one I built on the work bench and then installed is a slider, I wouldn't think it really maters. It's all in what is easier for you. With the KIT I'm rebuilding, I'm building the galley in place. The thing about building it in place, you have to think ahead because there is very little room for mistakes.dh wrote:Is there any advantage to building the gally/cabinets as a seperate unit and installing? It seems easier to me to put cleats on the walls and install one board at a time.
For my next one I'm going to build the cabs and then build the trailer around them. They will be all finished and perfectly square.
bobhenry wrote:Maybe we should build from the inside out
...or think about what your doing before you do it. It's called taking your time and thinking things out.
