Rickxr2 wrote:I went the cardboard route. Went to Lowe's and got some refrigerator boxes before they crushed them.
Senior Ninja wrote::?
Pattern? Template? i used a batten on the panel to become the side and bent it until I got a curve I liked, drew along the batten and cut out the sides. Worked for me.
afreegreek wrote:one of the best ways to mark your good stock for irregular shapes like a TD is to use 1/4" MDF then cut it out and sand the edge smooth to the final shape once you've decided that it IS the shape you're happy with. then you can trace it out on your good stock, and cut it out with a jigsaw. you can even use it as a template for a router to follow with a bearing equipped bit. (flushcut or template)
