48Rob wrote:Len,
Are they not installed as "floating" panels?
If they are, that would explain in part your success with them.
The rate of expansion/contraction has been the big concern using them for a teardrop, unless I'm thinking of a different product.
Rob
ya, they mean it's not bonded and only held in place with the trim. the idea being that it can "float" within the frame the trim creates as it expands and contracts from the temperature..Dan & Julie CO wrote:Sorry but what does float mean ? no adhesive?
it comes in different thicknesses and densities as well as different resin/plastics so it varies.. however there is some types that can be bent into pretty tight radiuses by heating it with a hot air gun..vwbeamer wrote:How flexible is this material. approx what radius can it bend around without cracking?
JIC wrote:Hi All,
How is it holding up to weather and temp. I ask this because some of the
post are rather dated and I what some up the date info.
I plan on using this on my small pickup camper.
Thanks
Jim Coleman
len19070 wrote:In about 1990-91 I built a fence around my Pool.
I wanted it to be a nice privacy fence to sit on the elevated concrete around the Pool.
So I built a painted Cedar fence with FRP for the insert panels.
No paint or anything, just raw FRP openly exposed, both sides to 20 years of North Eastern Winters, Summers, radical Temp changes, rain, sun, Chlorine etc.
And that's a School yard out back, balls hitting it, all the kids, and all things associated with a School Yard.
All the things I'm hearing that FRP is not supposed to do.
I recently had to reinsert a panel that was knocked out of its slot by something from the School Yard. Something that is a regular chore.
The panel was not broken, chipped, brittle or chalky.
In fact it looked as good as the day I put it in some 20 years before.
This is one hell of a test for a material that's not supposed to be able to withstand the Sun, Temp Changes and so on.
I'm convinced that this stuff can be used outside on say....A Trailer Roof that needs a solid nonporous sheet material.
Just my experience with the stuff.
Happy Trails
Len
Users browsing this forum: Bing [Bot] and 12 guests
