It's a shame not to use that little stove, it looks great. Surely there's a way to run the propane line a little bit away from your electrical, yes?
Looking at the materiel from Concord/Lifeline concerning AGM batteries the only thing that is vented is a very small amount of hydrogen gas, not enough to be explosive, and bear in mind these batteries can be mounted on their sides and will work upside down, even when punctured the acid does spill out. The hydrogen is the reason there are precautions about jumping a conventional car battery. i.e. ground to the frame not the battery. I just hate putting holes in things you don't have to. As an example the mounts for our solar cell will be put on using 3M VSB tape, no hols in the roof.
S. Heisley wrote: I checked the installation requirements and the available spacing meets them; barely, but it does. Woohoo!
Hey Sharon. It looks great! Just one suggestion though... You might want to turn that stove around so the big burner is in the back and the controls are up front. The way you have it, you'll have to reach over the big burner to get to the controls in the back. That might be a problem if you have a big boiling pot on there.
S. Heisley wrote:wlivesey wrote:Hey Sharon. It looks great! Just one suggestion though... You might want to turn that stove around so the big burner is in the back and the controls are up front. The way you have it, you'll have to reach over the big burner to get to the controls in the back. That might be a problem if you have a big boiling pot on there.
I thought of that but it won't fit frontward in a way that allows me to segregate the area to prevent a "KaBoom!".I tried it both your suggested way and the way it is in the picture, including right-handed knob motions. To my surprise, I found that my right arm didn't cross the big burner either way. With the left hand, it was a problem whether the controls were in front or on the right side because the stove design itself is not very good. With it this way, I can cook from either the front or the side and I'm right-handed anyway. If I kick the bucket (
R.I.P.) and my family sells it to a left-handed person, all he has to do is turn the unit around and the controls will be on the left!
It works!
So when are you going to post a pic of the pop top in place? I'm really wanting to see that!
