Im still hunting for wider moulding than what I used on our tear but no luck as of yet.
I do have some however I dont think its as wide as what you use in the USA.
planovet wrote:I used the insert moulding below. The picture isn't that good but the dimensions are 1 1/8" x 7/16".
Classic Finn wrote:Here the moulding I show in the photo is 11 euro per meter.
Classic Finn wrote:I was wondering as to what is the normal size or width of corner or edge moulding you folks use?
jackdaw wrote:Classic Finn wrote:I was wondering as to what is the normal size or width of corner or edge moulding you folks use?
Nice find Heikki![]()
I used the same sort of trim on our first build, It works great for fitting the side tent when you stitch a bit of awning piping along the edge of the tent.
I've been looking all over for it and can't find a supplier over here.
I thought it seemed a little narrow for the hatch.
This is the stuff I was after, Any chance of a link to a supplier ?
AS it happens , I've probably got enough trim (slightly diferent) to do my current project, but would love to know where to get some more from.
Dave
chorizon wrote:planovet wrote:I used the insert moulding below. The picture isn't that good but the dimensions are 1 1/8" x 7/16".
Mark, that's the stuff they had at the local RV supply, so for Heikki's sake I assume its pretty standard. It was $80 for a 20 ft. stick. Does that sound right? I thought it was a little high.
chorizon wrote:Classic Finn wrote:Here the moulding I show in the photo is 11 euro per meter.
That's ~$5/ ft. there vs. $4/ft. at the local supply. Similarly priced. Hmmm...I'm constantly getting bombarded by our metal suppliers that tell me setting up a special extrusion die for even a short-run is "very economical" and "much cheaper than I'd think". Maybe I'll put them to the test next week!
Classic Finn wrote:chorizon wrote:planovet wrote:I used the insert moulding below. The picture isn't that good but the dimensions are 1 1/8" x 7/16".
Joshua do you know where there is this moulding in Houston? Next to the Harbor..Im not kidding.
Classic Finn wrote:chorizon wrote:Classic Finn wrote:Here the moulding I show in the photo is 11 euro per meter.
Joshua how much for an extrusion die there?
packerz4 wrote:Heikki-
Are you starting a second tear? Did you finish yours?
Tam
packerz4 wrote:packerz4 wrote:Heikki-
Tam
still waiting for my answer Heikki!!!
Tam
