wannabefree wrote:It's unclear if you have epoxy/glass on the rest of the trailer. if you do, roughen a 2-4 inch wide strip on the old material where you are joining to new material with 120 grit sandpaper to get good adhesion. Plan on lots of sanding to level the new epoxy. If you use fiberglass, I would recommend 3-4 oz cloth. I used 6 oz and it's overkill. You don't really need the cloth, but if it's on the rest of the trailer I would maintain consistency. Just my opinion.
Steve_Cox wrote:Lynn,
In knowing your trailer and the problem you are trying to resolve, I would use epoxy and no fiberglass cloth to seal the new plywood you are going to install. By putting a couple of coats of resin on the both faces of the plywood and 3 coats on all the end grain it will be waterproof. The joints between the existing and new plywood could be filled with thickened epoxy and sanded before priming and painting again. Just the way I'd do it. Of course if you are looking for an opportunity to practice fiberglassing... this could be it
PS - it would be a good idea to sand down to bare wood on the existing painted surfaces before applying epoxy, would give a better bond.
doug hodder wrote:Lynn. I think a picture would be a great help. If it's a joint (roof to side) issue, you might be better off to tend to all the exterior joints. A local fix may be just that and the others may have an issue down the road. Better to take care of all of it now rather than let it get out of control. Just my opinion. Doug
Lynn Coleman wrote:To clarify it was put up with fiberglass the first time. I figured we would have to sand down to the wood. Does that mean we have to remove the fiberglass cloth that is on the other side to go down to the wood or will the new fiberglass simply adhere to the old glass?
Lynn
I didn't know it was glassed, sorry. Also didn't know water could get through fiberglass.![]()
BTW, is this a permanent or temporary til ya rebuild on the frame kinda fix?
doug hodder wrote:Does it sit outdoors all the time? Sorry to hear of your issues. Doug
thousands of boat owners find that out every year when they discover the cost of repairing their water damaged fibreglass boats. polyester resin an epoxy resin are by no means water proof. most of the damage is caused by osmosis but not all of it.Steve_Cox wrote: sorry. Also didn't know water could get through fiberglass.![]()
