I have my 12volt wiring and fuse panel in place along with a simple 30 amp Littel fuse breaker in line on the Positive side of my battery that will trip if the 12volt side of things get to hot (one of those small rectangular jobs with two posts for wires).
My question is on the 120 volt side. I have a Shore power plug and a GFCI outlet that powers the other two 120 plugs down line. I would like to have put some kind of breaker or fuse between my shore power and the GFCI plug. I don't want to put in a big gray box like a home wiring add-on box. I would rather have a breaker or trip switch similar to a Power strip trip button. My 120 volt usage will be mostly to power my Battery Tender. I usually don't have Shore power where I camp and my 120 volt requirements are minimal.
Do they make real simple trip switch circuit breaker l could wire between the shore power and the GFCI? I mean, they are on all the Power strips out there.
Jerry
