mikeschn wrote:I do think you can go with 1/8" skins both inside and outside.
My only question is, are you going to fill the walls with insulation? What kind? Because 3/4" plywood is only 23/32" but 3/4" EPS insulation is 24/32".![]()
You could even do 1/8" on the roof skin, if you put an additional 1/8" layer on the front of the teardrop to act as a rock guard.
dh wrote:mikeschn wrote:I do think you can go with 1/8" skins both inside and outside.
Alreayd a step ahead on this one, I have a neighbor who is the high school shop teacher. Run the foam through the surface sander, and it quickly makes it however thick I want it.
mikeschn wrote:dh wrote:mikeschn wrote:I do think you can go with 1/8" skins both inside and outside.
I don't have one of them surface sander thingies... Hmmmm....![]()
afreegreek wrote:a house is built using 2x4 or 2x6 studs spaced at 16 or 24 inches, held in place between the plates with two 3-1/4 inch nails top and bottom and sheeted with 1/2 OSB nailed every 4 inches around the perimeter and 6 inches in the field. no epoxy, no glue no screws. this will hold the weight of the second floor, another wall and the entire roof plus a snow load and all your stuff..
'cmon people, it's a 4x8 trailer for christ's sake. step away from the glue, the fumes are getting to you..
built anything that flies or floats? I have. here's a pic of the project I'm working on now..bobhenry wrote:in the past 25 + years, about the only thing I haven't built is a tear drop trailer so I know a thing or two about how stuff is made
You said a bunch there !![]()
In the past 10 I have been responsible fo 4070 residential homes a dozen 3 -4 story hotels a few health centers and 30 - 40 commercial strip malls. As near as I know they are all still standing.
As a hobby a couple hundred mini barns and garages and I have 2 tears and a couple tiny trailers under my belt but perhaps I should defer to your vast experience
EVEN THOUGH YOU NEVER BUILT A TEARDROP
