Shock Absorbers
Shock Absorbers
Postby Roberto » Mon Nov 14, 2005 4:36 pm
Well I "Dove In" this weekend and started my trailer. What's the Pro's & Con's on 'Shock Absorbers on TD's.
I don't see them on any of the build pages, so are they needed to keep the TD's from bouncing all over the place or are they just not necesary.
Thanks,
Bob
:o
Roberto
Postby PaulC » Mon Nov 14, 2005 4:50 pm
I'm not an expert on this but I've fitted leaf springs with an anti-rebound spring fitted to the top to minimise bouncing. I have not had a lot to do with torson type axles but I think that they would have anti-bounce built in. No shockers means keeping close to the original concept.
Cheers
Paul
PaulC
3rd Teardrop Club
Images: 36
Postby Chris C » Mon Nov 14, 2005 5:03 pm
I'm pretty sure the membership is divided fairly equally between torsion and leaf spring axels...................but I don't know too many who have chosen to use shocks. I don't believe it's a "retro" thing, but just that for regular road use they aren't really all that helpful. I'm going with the torsion axel because I understand they ride a little smoother and I'm not crazy about the thought of breaking things in the galley. :lol:
Chris :D
Chris C
Postby goldcoop » Mon Nov 14, 2005 5:17 pm
Roberto-
Check out:
http://www.shockwarehouse.com/cgi-bin/s ... rokit.html
Lots of good info. on retro-fitting shocks to trailers.
I added this URL to links, sources of supply!
Cheers,
Coop
goldcoop
Images: 32
Postby TRAIL-OF-TEARS » Mon Nov 14, 2005 5:54 pm
Roberto,
Welcome, There are a couple of tears out there with leafs and shocks. I think many people that want a smoother ride go torsion, and get an added benefit of adjustable ride height. I do not think it would be hard to retrofit shocks if you go leafs and find it too rough. Good luck
Steve J.
Home built Camp-Inn clone.
GO SPURS GO
TRAIL-OF-TEARS
Images: 41
Postby madjack » Mon Nov 14, 2005 6:06 pm
Torsion axles combine the benefits of spring and shocks in one unit. However they are more expensive and only the Flexiride brand offers an owner adjustable start angle. Some people have tried lowering their air pressure to get a better ride with some success...Due to having a senior moment, I can't remember who did a shock re-fit to their TD and documented it in their journal...hopefully they will read this and respond
madjack 8)
Postby Ken A Hood » Mon Nov 14, 2005 6:10 pm
That would be Larry and Diane's benroy...
http://www.outbackteardrop.com/
Disclaimer: I in no way resemble the avatar shown. Furthermore, I in no way have any affiliation to the Trailer Park Boys and more specifically Bubbles!
Ken A Hood
Images: 42
Postby fromscratch » Mon Nov 14, 2005 9:49 pm
Hi there. Just my 2 bucks(inflation) If aTorsion bar breaks you will be stuck where your at. If a leaf spring breaks you can readily get them.
Be at war with your vices, at peace with your neighbors, and let every new year find you a better man.
Benjamin Franklin
fromscratch
Re: Shock Absorbers
Postby Gage » Mon Nov 14, 2005 10:48 pm
Roberto wrote:Well I "Dove In" this weekend and started my trailer. What's the Pro's & Con's on 'Shock Absorbers on TD's.
Thanks,
Bob :o
All I can say is you missed two build sites. The Outback and mine. People have followed me and asked why my tear doesn't bonce. I just tell them that it must be the shocks.
Have a good day.
8)
IF I was to build another. It would have leaf springs and shocks.
Image Image Image
Gage
Images: 28
Postby madjack » Mon Nov 14, 2005 10:51 pm
jus4fun wrote:Hi there. Just my 2 bucks(inflation) If aTorsion bar breaks you will be stuck where your at. If a leaf spring breaks you can readily get them.
I have heard and agree totally with that point of view...what I would like to know is if anyone out there has had a torsion axle break on them...or even heard of one actually breaking...what I am talking about is the torsion design used by Dexter and Flexiride...not the coil torsion design found on old KenSkills and such...really not trying to pick a fight here...just for informational purposes and my own peace of mind, I would like to know this, since it is the argument for which there is no response to in the great suspension debate and the one possible weak point of a torsion axle......
madjack 8)
Postby Steve_Cox » Mon Nov 14, 2005 10:59 pm
Torsion axels, (at least the Flexiride I have, and the Dexter that others have) don't really have torsion bars, they use Goodyear rubber for the torsion effect not twisting bars of metal like some of the millions of cars on the road. But that's not the point of my post. It is a matter of preference. I liked the adjustable starting angle, and changable height ability. Also liked the fact the axle could be bolted right to the frame. 15" wheels and a relatively low ground clearance without having to use a drop axle. Although there is nothing wrong with drop axles if that is what you want. Lastly, torsion axles give you independent suspension. Guess that was about 3 cents worth of my opinion... Just the way I see it.
Steve 8)
Steve_Cox
Images: 196
Postby SteveH » Tue Nov 15, 2005 8:18 am
Jack,
Airstream trailers have been using the tortion type axles at least since the 60's, that I know of, and I've never heard of one breaking. I would think they are much heavier loaded than ANY teardrop could ever be.
SteveH
SteveH
Images: 42
Postby Nitetimes » Tue Nov 15, 2005 10:17 am
Do they break? Most definitely, in about 15 years of building and repairing trailers I have seen quite a few come back broke. But they don't generally break where you might think, I can only recall seeing 2 that the rubber went bad in them, don't know for sure what caused that tho. What I saw the most of was the spindle snapping off at the arm. (mostly on 2k axles) I replaced lots of them due to that but I also believe that the ones that were replaced for that reason should never have had torflex axles in the first place. They work well for what they are designed for but they don't handle abuse as well as spings do. If you aren't over loading them and staying to the highways/roads without craters in them you shouldn't have any problem on the other hand keep in mind that they can only flex so far, after that point something has to give and the only something there is the spindle. I personally don't care for them but I won't say for our application they aren't a good option. The choice between the two is mostly personal preference so use what you like.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby madjack » Tue Nov 15, 2005 1:07 pm
....thanks NT, that is the kinda info I was looking for
madjack 8)
Re: Shock Absorbers
Postby BobR » Tue Nov 15, 2005 4:19 pm
Gage...make that three build sites. They really work well...when the auto transport company delivered my tear to me in Florida when I moved from Torrance, CA, the driver told me he had "never" pulled a trailer that tracked so well or rode so smoothly. He wouldn't have said that if he pulled it before I mounted the shocks :D
Bob Richert
Parrish, FL
"Be glad of life because it gives you the chance to love and to work and to play and to look up at the stars"
BobR
