Glue my stainless steel sides to plywood
Postby georgedombeck » Fri Feb 19, 2010 7:48 pm
Thinking of using construction adheasive. Yes no maybe. thanks, george
georgedombeck
Postby JJKC » Fri Feb 19, 2010 8:14 pm
Most people on here just float it and use the trim to hold it on or indoor/outdoor carpet adhesive
JJKC
Images: 15
Postby Arne » Sat Feb 20, 2010 12:04 am
I don't see any type of glue holding it... smooth metal to wood is extremely difficult....but if you find any, let us know.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Ward » Sat Feb 20, 2010 1:43 am
George you wouldn't want to use the heavy duty construction adhesive if the SS is very thin, I would suggest either the spray adhesive as mentioned or in the same section as the const, adhesive will be mirror adhesive that will not be so thick. In other words you would not like the outcome of using a thick adhesive as it would be noticeable through the skin.
Also I would not soley rely on any adhesive alone. Hold it with trim as mentioned or use som SS screws.
Regards
07' Harley Street Bob
04 f350 4x4 powerstroke
10' GMC Acadia 8 passenger SLT (TV)
***NO REGRETS******
Ward
Images: 29
Postby planovet » Sat Feb 20, 2010 9:02 am
JJKC wrote:Most people on here just float it and use the trim to hold it on or indoor/outdoor carpet adhesive
That's what I would do :thumbsup:
ImageMark (& Cindi)
planovet
The Cat Man
