Maybe some of you can help me a little bit. About the only thing I know about solar panels are they are shiny. I saw this, and was wondering if it would be sufficient to keep a charge, and run some minor appliances. What is good and what needs to be different? Is this too much/big for a tear? Any help would be appreciated.
Thanks.
Nominal Peak Power [Pmax] +/- 3% 60 Watt
Maximum Power Voltage [Vmp] 18V
Maximum Power Current [Imp] 3.34A
Short-Circuit Current [Isc] 3.63A
Open-Circuit Voltage [Voc] 22.5V
Optimized Cell Efficiency 16.8%
Limits
Operating Temperature -40C to 85C
Maximum System Voltage 715VDC
Temperature & Coefficients
NOCT 48C +/-2C
Current Temperature Coefficient 0.06 +/-0.01
Voltage Temperature Coefficient - (78 +/- 10)
Power Temperature Coefficient -(0.5 +/- 0.05)
Additional Data
Number of Cell & Type of Connection 24, Serial Connection
Dimension Length: 800 mm
Width: 550 mm
Height: 35mm
Weight 5.5 Kg
Guaranteed Power Output 15 Years: 90% of its nominal power rating
25 Years: 80% of its nominal power rating
Warranty Period 5 Years Limited Manufacturer Warranty
Replacement of Defective parts. Labor excluded.
