synaps3 wrote:From my understanding of rubber, it only degrades:
1. When exposed to excess strain (too much weight, extreme impacts)
2. When exposed to sun (UV rays) for extended periods of time
3. In extreme heat / extreme low humidity
Really, as long as you stay well within the weight rating of the axle, your torsion axle should hold out for the life of your trailer. As they age, the axles will become less effective and may eventually need replaced. This is me speaking from logic though -- perhaps someone more knowledgeable than I can chime in and speak from experience...
Speaking from my experience with my Airstream, and the time spent on those forums (Airstream uses Dexter and/or Henschen Torsion Axles)...
Expected lifespan is 15-20 years. While some have held out for upwords of thirty, that is to the upper level. The biggest enemy of a torsion axle is sitting, unused. They can "set" from lack of use and the dead weight sitting on them. The rubber does experience degradation over time, but it won't be exposed to UV rays, or excess strain if you order the appropriate weight rating.
However, a Teardrop weighs nothing near the weight of an Airstream, so the weight isn't going to be an issue. Just make sure and use your trailer at least a couple times each year.
