Micro469 wrote:for a trailer around 1000 lbs, would 1" tubing be enough around the perimeter and cross pieces?
This is getting too complex to describe in text - we really need to be looking at drawings which can't mean different things to different people.
In general, I think 1" tube would be enough for a body frame and cross-members.
However:
- attaching axles to 1" tubes isn't easy (though you could double up the 1" where the axle goes);
- if you are using a single (not A-frame) tongue, then those cross-members need to be stronger, as you've said;
- the length of the tongue and its 'bury' (how much is under the floor) matter - there is no such thing as "this tube is good for any length tongue".
With Rocky's comments about single 2x2x1/8 tongues, we need to bear in mind that I seem to remember his trailer is fairly heavy and it had a hugely long single tongue to start with.
Andrew
