dreadcptflint wrote::o
I finally ordered my set up tonight. https://eco-distributing.3dcartstores.com/RV-Roof-Mount-Solar-Kit-with-Kyocera-135watt-Panel_p_623.html
It's doesn't come with a MPPT but it is a start. I couldn't pass up the price.
Rock wrote:Definitely not for everyone but I just bought this same item last week for $81 plus $10 shipping. So that's $91 for 125 watts of solar power. Of course there will be building the panels, but all I should need is some window glass and aluminum angle.
http://cgi.ebay.com/75-WHOLE-3-x6-Solar ... 2a04faf4d0
Once again - not for everyone but I've been messing with this stuff for almost 35 years. BTW this same item has gone for as little as $67 in the last couple weeks.
Eric
doug hodder wrote:I'm very ignorant on the solar technology. You're the Solar God! Doug
bdosborn wrote:dreadcptflint wrote:
Its a different color than most panels, supposed to be a more appealing. Whatever, it's the 135 watts I'm interested in! It has MC4 connectors, you might check and see if you'll need any to install it.
Its nice that the controller has metering. I think its important to have some kind of metering so you can tell what's going on with the panel. I can tell if there's a shadow on the panel using my meter.
Make sure and post some pictures of the install!
Thanks for the headsup. I am one tongue box and dry weekend away from doing the install. I double checked and sure enough plenty of cable and no second MC 4 Connector. I am half tempted to cut them off and spice in the cable but can see the power of using a connector.
What do you think of a disconnect tool? Like http://store.solar-electric.com/ditoformc4co.html
Does a standard crimper work or do I have to get a special crimper as well?
BillZ wrote:Bruce,
Are you inverting to AC or do you use DC powered lights? I didn't see you talk about using an inverter.
I'm not familiar yet with the electrical setup of a camper. Is there normally an inverter setup w/the battery?
