1/2" or 1/4" ply
1/2" or 1/4" ply
Postby timlsalem » Wed Mar 03, 2010 5:30 pm
I've always used 1/2" ply on my walls but am thinking 1/4" would work also. If you've built your tear out of 1/4", how is it holding up for you? Is there anything different I should know about constructing with 1/4" opposed to 1/2"?
KIA'S--MIA'S--POW'S--DAV'S--are what our freedom cost us
timlsalem
Images: 40
Postby Cliffmeister2000 » Wed Mar 03, 2010 5:48 pm
Are you talking sandwich construction? If so, I used 1/4" on the outside, 1/8" om the inside, and 1x3 framing. It's a year or so old, and so far, it still looks brand new! :thumbsup:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby planovet » Wed Mar 03, 2010 7:34 pm
I used 1/2" but could have (or maybe should have) used 1/4" ply. But due to the dimensions of my tear, I had to glue 3 pieces of 5x5 ply together to make the sides (actually two 5x5 pieces and one 5x2.5 piece for each side). I painted my sides so I did not want the joints moving; therefore I used biscuits along each seam. I could not have done that with 1/4" ply. If I didn't have any seams or was using aluminum to cover the wood I would have used 1/4" (I used 1/8" on the roof under the aluminum).
ImageMark (& Cindi)
planovet
The Cat Man
Postby timlsalem » Wed Mar 03, 2010 8:33 pm
I'm building a 5x10 but going to fiberglass over ply.
timlsalem
Images: 40
Postby Arne » Wed Mar 03, 2010 9:32 pm
I used some millimeter thing from h/d, slightly less than 1/4... next time, if there is a next time, I'd go with 1/8th, foam filled..
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby RogHodge » Thu Mar 04, 2010 7:47 pm
This is encouraging me to stay the course and use 1/8 in and out. Everyone seems to over build or say they did or warn a guy not to. I guess if it’s not a sandwich type construction 3/8 or so might be a minimum- but that is only a guess.
For those who would like to have a look I have a build journal and covet your feedback.
http://www.tnttt.com/viewtopic.php?t=33547
RogHodge
Images: 51
Postby b.bodemer » Thu Mar 04, 2010 8:02 pm
My sides are 1/2" but the top and hatch are 1/4". I used vertical spars and it's plenty strong.
Barb
b.bodemer
Images: 328
Postby dwgriff1 » Thu Mar 04, 2010 8:07 pm
All the plywood I used was 1/8.
Remember Andrews definition of the difference between tough and strong?
dave
dwgriff1
Postby Mikey1975 » Thu Mar 04, 2010 8:09 pm
my first build was 3/4 oak ply outside then 3/4 foam then 1/4 oak now thats over built LOL!!! :lol:
Mikey1975
Images: 23
Postby timlsalem » Thu Mar 04, 2010 8:17 pm
how is that 1/8" holding up Dave? Is it sandwished?
timlsalem
Images: 40
plywood
Postby spud233 » Fri Mar 12, 2010 8:55 am
8) jest built 1st td.used 3/4 on sides,1/4 bc on front and galley walls and 1/2cdx on floors.insulated with3/4 foam galley wall,overhead and front wall
spud233
Images: 14
Postby Grid Runner Adventures » Fri Mar 12, 2010 10:18 am
i will not have any internal framework in my build just laminating 1/8th inch ply on each side of 3/4 inch foil foam board.
well. i will route out chanels and glue in wood strips for anchor points for the interior wall/cabinets/ bench/bed and such too. but they will not go through the entire wall.
im looking to have no thermal transference points. except in the very most outer edge of each wall/roof panel.
will be able to winter though this thing when im done. while i get first property and build first home.
www.offgridrving.com
Follow my build of a off grid camper that is 6x8 and I will live in it for an entire year!
Google Is My College
Postby rpm750 » Fri Mar 12, 2010 5:24 pm
Cliffmeister2000 wrote:Are you talking sandwich construction? If so, I used 1/4" on the outside, 1/8" om the inside, and 1x3 framing. It's a year or so old, and so far, it still looks brand new! :thumbsup:
So how does that compare weight wise to a 3/4" sheet of ply? I'm sure it has better insulation value but I'd like to know how it compares weight wise.
Thanks
rpm750 aka"Average Bob"
1964 Type 1 sunroof
1966 Type 1 "CaLook" O'Bugga
1968 Type 1 Cut up
Soon to be Compact Travel Trailer Owner!
rpm750
Postby Cliffmeister2000 » Fri Mar 12, 2010 5:30 pm
Thanks
It's lighter, but I don't know how much lighter.
I did it because the teardrop I bought was made out of 3/4" ply, with aluminum skin, and the screws that were placed in the endgrain of the ply were all pulling out, and the ply was delaminating. With sandwich, I got nice wood to screw to everywhere I needed it.
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby mikeschn » Fri Mar 12, 2010 5:37 pm
figure 25 pounds per 1/4" of plywood...
so a 4x8x1/4 = 25 pounds
a 4x8x 1/2 = 50 pounds
a 4x8x 3/4 = 75 pounds...
You get the idea...
