Mike Angeles wrote:I cut my rough profile with a Jigsaw and cleaned up the edge with a flush trim bit on a Router. very clean, Id recommend a lower speed on your router as it tends to melt or gum up.
save your money and don't but the nibbler or shear, you don't need it for this job, buy a trim or regular router instead. I saw that rotozip sells a 1/4" collet so you can but a regular flush trim bit if you have the rotozip already.Etech wrote:I want to thank all who have replied. All are of great help.
I don't own a router, but do have a RotZip. Can I possibly purchase a RotZip bit to do the finish trim. I guess I'm getting ahead of myself with this question. I will look into 18 Gage Sheet Metal Electric Shear that Nobody spoke of, then do the final trim with the RotoZip, if there is a correct bit available
afreegreek wrote:save your money and don't but the nibbler or shear, you don't need it for this job, buy a trim or regular router instead. I saw that rotozip sells a 1/4" collet so you can but a regular flush trim bit if you have the rotozip already.Etech wrote:I want to thank all who have replied. All are of great help.
cool, now just buy a 1/4" shank flush trim bit in 1/2" diameter and you're set. you can buy a really cheap one too, no need to spend the money on a Frued or some other premium brand. that matters if you're trimming wood and need a really sharp bit to prevent tearing out the grain.. at our shop we use the cheap ones for metal and plastic laminate and they work just fine.Etech wrote:afreegreek wrote:save your money and don't but the nibbler or shear, you don't need it for this job, buy a trim or regular router instead. I saw that rotozip sells a 1/4" collet so you can but a regular flush trim bit if you have the rotozip already.Etech wrote:I want to thank all who have replied. All are of great help.
I do have the 1/4" collet.
any single flute or dual flute bit will work, any brand as well. this is what they look like...Mikey1975 wrote:what kind of router bit do you all use i know aluminium trim bit but what brand???
