afreegreek wrote:clamps are to hold two pieces in place. if the fit is good masking tape will work and if you use your noggin you can build without any clamps.
Larwyn wrote:afreegreek wrote:clamps are to hold two pieces in place. if the fit is good masking tape will work and if you use your noggin you can build without any clamps.
Now that's amazing! So what type of sticky tape would you use to hold the plywood down on the curved ribs as in the picture I posted above? I know there are a few hundred dollars worth of clamps shown in that picture (what a waste!) so I would really like to know how that job, among many others are accomplished with a bit of sticky tape. Such as; what kind of tape would you use to hold a 20 foot length of 3"x3"x1/4" angle iron 10 feet off the ground to the side of four 6" I beams? It only needs to hold long enough to get the angle tack welded in place.
I suppose "use your noggin" means driving nails with your head?![]()
why not just tack weld a few pieces on the i beams for the angle iron to rest on??Larwyn wrote:afreegreek wrote:clamps are to hold two pieces in place. if the fit is good masking tape will work and if you use your noggin you can build without any clamps.
afreegreek wrote:how many clamps do you need to apply solid wood edges to plywood panels??
monofilament tape, the stuff with the strings in it.. that stuff is super strong and you can pull a lot of force with it.. you just have to get it to stick to the wood. clear 3" packing tape sticks well to wood, place it where you'r going to lay the mono tape. you need lots of surface contact area.. like a foot of length or more if you're going to pull really hard.. I use the roll to pull with or if I want to really honk on it I cut it and roll a bit of the end on a piece of 1" dowel to serve as a handle.StPatrón wrote:afreegreek wrote:clamps are to hold two pieces in place. if the fit is good masking tape will work and if you use your noggin you can build without any clamps.
What type tape would you suggest I use when skinning my hatch?
Users browsing this forum: Jimbodub and 8 guests
