bve wrote:afreegreek wrote:how many clamps do you need to apply solid wood edges to plywood panels??
Interesting, so how much tension is on the tape? It doesn't look like much just a snug wrap. I've seen it used to hold laminate and other thin pieces in place but never something as thick as that. What kind of glue is being used and what is it's set up time?
afreegreek wrote:Larwyn wrote:afreegreek wrote:clamps are to hold two pieces in place. if the fit is good masking tape will work and if you use your noggin you can build without any clamps.
Now that's amazing!
what does iron have to do with wood?? and to answer your question, I'd use monofilament tape and maybe a bit of seine twine. and yes I could do it with no clamps
I gave an answer as to HOW it COULD be done WITHOUT clamps to illustrate that things CAN be done without them. not which is the faster more efficient way.. the moral of the story is... if you got 'em, use 'em.. if not, use your head rather than you wallet..Larwyn wrote:afreegreek wrote:Larwyn wrote:afreegreek wrote:clamps are to hold two pieces in place. if the fit is good masking tape will work and if you use your noggin you can build without any clamps.
Now that's amazing!
Your statement was about clamps, iron and wood are both building materials on which clamps are often used, you did not qualify your statement as only applying to wood.
Even if a welder did choose to use your procedure to attach the angle iron to that beam, you can bet that the temporary support cleat which you described would be clamped into place to hold it in position before/if it was tack welded. Why not save time, material and the later clean up involved with using the temporary support cleat and simply clamp the angle in place, weld it, and be done?
The horizontal strips you see in the picture of my hatch with the clamps are not battens, they are clamping cauls. In this case the cauls are oak 1x2's which I tapered from both ends to the center so that when I clamp the two ends down tight they apply a more even pressure along their full length rather than bowing up in the middle. This causes them to hold the plywood in contact with those inboard ribs which are not so easy to reach with a clamp.
The anvil was used on the flat wall panels to serve much the same purpose as the cauls served on the hatch. In your case, I suppose if you need a "gravity clamp" you would certainly have a container of some sort which you could fill with something heavy to serve the same purpose (a crock comes to mind).
Mauleskinner wrote:I pretty much quit buying them a while back...the left one is boughten, the others are homemade...
[/u]
Grid Runner Adventures wrote:i couldnt find the plans to make those clamps
