actually the "special" sharpening a Forrest needs is called a finer grit grind than what other blade companies and sharpening services use.. the sharpening service I use will do it if requested for a few dollars more.Gary J wrote:I spent the $100+ price on a very nice Forrest combo blade and then read wood magazine's test of blades. They rated the comparable tooth Rigid blades (Home depot) as a better blade at a $40+ price, so I bought one. It is a much narrower blade and makes a smoother cut. I use the Rigid blade most of the time and reccommend it when ever asked. You can purchase almost 3 blades for the price of one Forrest (which is a great blade). When the Rigid blade gets dull I intend to chuck it. The Forrest blade need special sharpening.
Gary
yes and no. a very good high speed steel blade well sharpened will cut smoother than a comparable carbide blade but for next to no time and will dull in a few cuts when cutting anything but solid wood. plywood, particle board, MDF OSB paralam etc will kill them right away.. they also take a good level of skill to sharpen and need something a lot finer than a file to do it. a stone is what you need to finish it up after filing/grinding and if you can do that, you can do a carbide blade as well you just need the right stone or use diamond abrasive disk (like I do) the process is simple though, all you do is joint the tips (grind a flat on the tips all around the blade) and file/grind the face and the top of the tooth until the flat barely disappears. simple but it's a skill and it takes time to do it. I have an old European veneer blade about 6 inches in diameter and has 200 teeth. it takes me about 4 hours to do it.Larwyn wrote:Anybody ever stop to think that a blade which can be easily sharpened by the user might be a better choice for the non professional (maybe even the pro)? Could be that $20 for a blade, $5 for a file, $0 per hour = a bargain for a home woodworker. I'm just curious, not trying to change anybody's mind. I have used good Freud carbide blades all along, but now that I no longer make "half a blade per hour", I'm thinking I might just be better off with somthing I can sharpen myself? I know I have a renewed apreciation for the older pocket knives I have which are made of high carobn steel as opposed to the high dollar oens I have with more exotic steels which hold an edge for a long time but are quite difficult to sharpen when they do dull.
afreegreek wrote:actually the "special" sharpening a Forrest needs is called a finer grit grind than what other blade companies and sharpening services use.. the sharpening service I use will do it if requested for a few dollars more.Gary J wrote:I spent the $100+ price on a very nice Forrest combo blade and then read wood magazine's test of blades. They rated the comparable tooth Rigid blades (Home depot) as a better blade at a $40+ price, so I bought one. It is a much narrower blade and makes a smoother cut. I use the Rigid blade most of the time and reccommend it when ever asked. You can purchase almost 3 blades for the price of one Forrest (which is a great blade). When the Rigid blade gets dull I intend to chuck it. The Forrest blade need special sharpening.
Gary
OH, and if you're getting better cuts from a $40.00 blade, there's something wrong with your saw or you have a crap saw because on a good cabinet saw the Forrest blade will make a smoother cut per tooth than ANY blade out there. I get as advertised, smooth as sanded surface with no tear out. in fact the difference is so great that I bring my own blades to work and pay to have them sharpened myself just so I can have the quality of cut I've become used to from them..
most of there blades styles are available in the thin (3/32) kerf too.
OK, lift the throat cover and remove blade. take cold chisel and hammer. place chisel against arbor flange and give good firm hit with hammer.. the harder the better. enjoy equally crappy cuts from every blade you ever buy..Larwyn wrote:afreegreek wrote:actually the "special" sharpening a Forrest needs is called a finer grit grind than what other blade companies and sharpening services use.. the sharpening service I use will do it if requested for a few dollars more.Gary J wrote:I spent the $100+ price on a very nice Forrest combo blade and then read wood magazine's test of blades. They rated the comparable tooth Rigid blades (Home depot) as a better blade at a $40+ price, so I bought one. It is a much narrower blade and makes a smoother cut. I use the Rigid blade most of the time and reccommend it when ever asked. You can purchase almost 3 blades for the price of one Forrest (which is a great blade). When the Rigid blade gets dull I intend to chuck it. The Forrest blade need special sharpening.
Gary
If a saw can have a defect that would cause it to cut better with a cheap blade than a "better" blade I want my saw to have that defect!! What is it and how can it be induced in a saw which, unfortunately, is not defective?![]()
afreegreek wrote:OK, lift the throat cover and remove blade. take cold chisel and hammer. place chisel against arbor flange and give good firm hit with hammer.. the harder the better. enjoy equally crappy cuts from every blade you ever buy..Larwyn wrote:afreegreek wrote:actually the "special" sharpening a Forrest needs is called a finer grit grind than what other blade companies and sharpening services use.. the sharpening service I use will do it if requested for a few dollars more.Gary J wrote:I spent the $100+ price on a very nice Forrest combo blade and then read wood magazine's test of blades. They rated the comparable tooth Rigid blades (Home depot) as a better blade at a $40+ price, so I bought one. It is a much narrower blade and makes a smoother cut. I use the Rigid blade most of the time and reccommend it when ever asked. You can purchase almost 3 blades for the price of one Forrest (which is a great blade). When the Rigid blade gets dull I intend to chuck it. The Forrest blade need special sharpening.
Gary
