slowcowboy wrote:How would 6 volts recharge a 12 volt battery.
slowcowboy wrote:I saw a post online on heating a teardrop in which someone suggested a old bike generator like the typs used as kids to run a head light to make a wind turbine out of. I get way to much wind in wyoming am already working on a idea for a large windturbine in my back pasture. So it was very easy to latch on to this idea. I did some research on ebay and found lots of the old bike generator and head light sets. Most informaton on them said the old bike generators are 6 volt. They run a 12 volt head light and a 6 volt tail light and the generator itself is 6 volt. How would 6 volts recharge a 12 volt battery. and would a 6 volt battery do a good job at trickle charge much like the small 5 watt solar panels. I amit I am curous on this idea and would like some feed back from someone on here more knowledgable and up on electricty. I have even thought about running the generator on my teardrops tires much like the bike it was desinged for on a homemade bracket. But won't do this idea as my tires on my teardrop probale will spin the bike generator way to fast and burn it up. Can 6 volt do a good job at trickle charging 12 volt??????? Slowcowboy working on ideas again.
