pre heat test for your dutch oven
Postby bobhenry » Wed Mar 17, 2010 1:50 am
I found this on an Australian D.O. forum.
Simple and practical
Testing camp oven heats by paper test
Here’s a way to determine the heat of an oven when using coals from a fire.
Pre-heat the oven on a bed of coals. Place a piece of paper inside the oven to find out what heat the oven is at. The paper will change color according to the heat of the oven within a few moments.
HEAT DEGREES PAPER TEST
Very hot oven 500 Dark brown
Hot oven 375-400 Light brown
Moderate oven 325-375 yellow
Slow oven 250-325 Crust
TOO BLOODY HOT
Black & on fire!
didn't understand "crust" but the rest made sense just toss in a piece of white paper and give it a few minute and read your results.
Postby S. Heisley » Wed Mar 17, 2010 11:05 am
Clever idea, BobHenry. Thanks for sharing. :thumbsup:
I'm guessing that "crust" might be a little bit of brown on the edges and maybe a slight curling around the edges of the paper, sort of like a pie crust?
Postby StPatron » Wed Mar 17, 2010 11:39 am
Thanks BobHenry, I'll have to try that out.
I've used the "how long can you comfortably keep your hand over it" method before, which works pretty well.
I think Sharon's on target with the crust description, but you might have to make a research trip to Australia in order to confirm it. :lol:
StPatron
Images: 297
Return to Cast Iron
