TwilightLane Cubbie Build
Postby TwilightLane » Wed Mar 17, 2010 11:22 pm
So I laid the frame on the ply and lined everything up. I used the clamps to hold everything in place.
Sure enough, there is about a one inch lip as the frame is narrower than the ply.
Rob & Lori
Aspen & Tundra
My Instructable: http://www.instructables.com/id/Teardro ... l-Trailer/
TwilightLane
Postby TwilightLane » Wed Mar 17, 2010 11:24 pm
So I lined up a 2x3 as a cutting guide to run the circular saw. It had a slight bow in it, so I used several clamps to hold the line.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Wed Mar 17, 2010 11:26 pm
I moved and replaced the clamps as I worked down the cut. The two middle clamps actually caught the strip so I didnt have to worry about it tearing or breaking at the end of the cut. Nice...
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Wed Mar 17, 2010 11:27 pm
Framing out the hatch. Used some scrap 2x2.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Wed Mar 17, 2010 11:33 pm
Once I measured and determined where to cut the hatch, I drilled a few tiny holes where I knew I wanted the plunge cuts. Then I set the frame to the side and flipped over the ply. In retrospect, I don't know why I flipped over the plywood. I could have done it from the bottom side.
I used the circular saw to make the plunge cuts. Again I was worried about tear or breaking the edge of the cut as I finished the cut. My solution was to use a crosswise piece to hold the cut out hatch.
That worked really well.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Wed Mar 17, 2010 11:35 pm
So the funny thing that happened while I was cutting out the hatch: I didnt want to cut those 2x2s underneath that were supporting the ply. SO I took one out. I _thought_ I had moved the sheet over enough to miss the remaining one when I made my cuts...
Yeah not so much. Genius!!??
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Wed Mar 17, 2010 11:38 pm
At any rate, a lot of progress today. St Paddy's day.
(Notice the piece of conduit replacing the cut 2x2 :lol: )
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Thu Mar 18, 2010 1:53 am
I don't know what is going on out on the main 'General Discussion' forum. But clearly there are some ruffled feathers about advice and peoples tone and whatnot.
For the record, I have a very thick skin and can give as well as I get. If you see me doing something wrong or dumb, please pipe up. Don't hold back. We'll have a good laugh, fix it and move on with life. Thanks in advance.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby aggie79 » Thu Mar 18, 2010 8:39 am
Rob,
You're moving right along!
For what it's worth, I think you're doing a great job. (While I'm not new to construction or woodworking, I'm a TD newbie. I guess that label goes away after you finish your first build.)
Keep it going!
Postby TwilightLane » Sat Mar 20, 2010 12:11 am
Okay, so I got all the holes drilled and countersunk. I used a chalk line to line up where to attach the ply to the frame.
Uh, yeah. I'm a little anal retentive. Why do you ask?
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Sat Mar 20, 2010 12:17 am
The plans called for a square of ply under the front to reinforce the floor. I didnt have anything that I thought would work. What I did have was a piece of oak. Hard as hell. It came from a pallet that I tore apart. I figured it was stout enough to carry the spare tire.
I drilled a couple of holes that lined up to bolt holes on the rim.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Sat Mar 20, 2010 12:19 am
Ok. So I've the got the ply and frame all prepped. Now to glue and attach em.
Here is the glue...
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Sat Mar 20, 2010 12:22 am
Lotsa screws. Glue squeezing out.
Overkill you say? Is a pig's butt pork?
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Sat Mar 20, 2010 12:25 am
Yeah. More screws. I do like my DeWalt drill.
All screwed and glued.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Sat Mar 20, 2010 12:27 am
Now that is some serious fine craftsmanship. Heh.
Rob & Lori
Aspen & Tundra
TwilightLane
