I finally got it completely enclosed on the exterior, and it appears that I haven't sunk a screw or staple into any of the wiring...a real +! I also smoothed out the joints with a belt sander and epoxied up staple holes/ voids and over the joints. I will completely coat out the exterior with a coat of epoxy prior to skinning. My thoughts are that if there is any leak, at least it won't go into the luan and become a sponge. I've seen enough that have leaked that I can't help but think it will help with any potential water problems in the years to come. The end grain on the window cuts/door will also be coated out.
I've also started the curtains, using the Michael Miller vintage trailer fabric. I put a coral colored flange between the curtain body and the upper teal piece to help tie in all the colors. It is going to take 16 of these panels to get all the curtains done on this one.
It's down to the point now that I can put together a punch list of things to take care of on finishing. It should be out of the garage this weekend, when I will do my final cut on the wheel well prior to skinning. Doug
