Registering a Trailer "Kit" in PA - March 2010
Postby absolutsnwbrdr » Thu Mar 25, 2010 2:16 pm
Back on January 1, 2007, PennDOT made registering a "kit" trailer a real pain in the a$$!
After following registration procedures and suggestions from members here, I've discovered the most up to date registration information for anyone assembling and registering a trailer kit in PA.
There was another thread, but the most current information is listed below. I have obtained much of my information from PennDOT's Specially Constructed Vehicle Fact Sheet, as well as my own experiences this week. I visited with multiple notaries yesterday and today, and was given the exact same information at each.
SO HERE IT IS>>>
_________________
PROCEDURE:
1. Buy your trailer kit . KEEP YOUR RECEIPT! Put it with your trailers Certificate of Origin.
2. Assemble your kit and be sure that all lights work, and safety chains are present. (If you put a plywood deck on your trailer, put that receipt with your Certificate of Origin and trailer receipt.)
3. Take 4 pictures of the assembled trailer. Be sure to show each side of the trailer, making sure to show that all lights are in place. Also be sure that the safety chains are clearly visible in a couple of the pictures.
4. Find an Enhanced Vehicle Safety Inspection Station. If this link expires for some reason, you can find the stations list from PennDOT's Motor Vehicle Services website. While you're at PennDOT's Site, print out MV-426B. Fill in as much information on the form as you know.
5. Find a certified weigh station. These are typically found at concrete plants, quarries, etc. Go get your trailer weighed. This shouldn't cost more than $5. For your $5, they will give you a piece of paper that says your trailer weighs XXX lbs.
6. Call the inspection stations in your area to find one with a reasonable price. Be sure to tell them that you have a trailer assembled from a kit. I tried to go to a regular inspection station, and they refused to do it. The first "enhanced station" I called wanted $200 for the inspection. I called another place and got my enhanced inspection for $53. HINT: Look for the "mom-and-pop" garages on PennDOT's list.
7. Take your trailer to the enhanced inspection station. Also take your 4 pictures, your insurance card for your tow vehicle, your MV-426B, and your certified weight slip. The inspector will complete the MV-426B, and give everything back to you. My inspector even signed the backs of the 4 pictures, as if to certify them.
8. Go to a notary that does vehicle registration. TAKE EVERYTHING WITH YOU: Trailer assembly manual, receipts, Certificate of Origin, the 4 pictures, and your weight slip. They may or may not ask for the assembly manual... better safe than sorry. For registration and notary fees, you can expect to pay $60-$80 total. NOTE: I called PennDOT this afternoon, and this type of registration CAN NOT BE DONE over the counter at PennDOT's headquarters in Harrisburg.
FINAL NOTE: Each notary I contacted told me that it takes 4-6 weeks to receive your plates. PennDOT told me the exact same thing. I will update this when I recieve my plates. My paperwork went in today, March 25, so we shall see.
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
UPDATE>>>
The notary received my title and license plate on Saturday April 3.
Thats 1 week and 2 days since the paperwork was sent to PennDOT.
While that is MUCH FASTER than PennDOT claims, DO NOT WAIT until the last minute to register your trailer.
Hope your registration goes as "smoothly" as mine!! :D
Last edited by absolutsnwbrdr on Tue Jul 24, 2012 10:48 am, edited 2 times in total.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Re: Registering a Trailer "Kit" in PA - March 2010
Postby Creamcracker » Thu Mar 25, 2010 5:29 pm
absolutsnwbrdr wrote:Back on January 1, 2007, PennDOT made registering a "kit" trailer a real pain in the a$$!
SO HERE IT IS>>>
_________________
PROCEDURE:
8. Go to a notary that does vehicle registration. TAKE EVERYTHING WITH YOU: Trailer assembly manual, receipts, Certificate of Origin, the 4 pictures, and your weight slip. They may or may not ask for the assembly manual... better safe than sorry. For registration and notary fees, you can expect to pay $60-$80 total. NOTE: I called PennDOT this afternoon, and this type of registration CAN NOT BE DONE over the counter, at PennDOT's headquarters in Harrisburg.
FINAL NOTE: Each notary I contacted told me that it takes 4-6 weeks to receive your plates. PennDOT told me the exact same thing. I will update this when I recieve my plates. My paperwork went in today, so we shall see.
Wow..what a PAin!
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby toypusher » Thu Mar 25, 2010 7:13 pm
Zach, when I did mine back in 2005, they said 4-6 weeks and it only took 3. That was through a 'Runkels' and it came back once and I needed to send additional information in.
toypusher
Images: 324
Postby absolutsnwbrdr » Thu Mar 25, 2010 7:52 pm
toypusher wrote:Zach, when I did mine back in 2005, they said 4-6 weeks and it only took 3. That was through a 'Runkels' and it came back once and I needed to send additional information in.
Nobody at Brimmers had a clue about registering a kit trailer. Went once yesterday and the lady told me to come back today. Went again today, another lady said she couldnt do it either. GRRRRRR. Ended up at Runkles down in Red Lion after work today, and we got the paperwork filled out without a problem.
Tearstock is in a bit more than 6 weeks, so I should have tags by then. If not, I'll be borrowing a friends trailer tag :twisted:
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Newman39Fan » Thu Mar 25, 2010 8:25 pm
WOW, That really stinks! I took my Cert of origin and receipt to the DMV in Indiana. After writing a $53 check I walked away with a plate. The trailer was still in the box!
Newman39Fan
Postby len19070 » Fri Mar 26, 2010 4:08 am
" I've never gone through so much trouble to give somebody money for nothing in my life"
Len Daddona "1983"
len19070
Images: 24
Postby toypusher » Sat Mar 27, 2010 6:11 am
len19070 wrote:" I've never gone through so much trouble to give somebody money for nothing in my life"
Len Daddona "1983"
Ain't it the truch, Len??? :lol:
toypusher
Images: 324
Postby Classic Finn » Sat Mar 27, 2010 1:23 pm
Pain in the buttocks, but come here and you,ll see what a pain it is also.
Darn beauracrats of our country.. :? :?
Now 1st of 2010 all lighting install has to be inspected seperately in addition to the trailer or tear..inspection. :shock: :x :x :x
Classic Finn
Midnight Sun Voyager
Images: 146
Postby absolutsnwbrdr » Sun Mar 28, 2010 10:29 am
Classic Finn wrote:Pain in the buttocks, but come here and you,ll see what a pain it is also.
:thinking:
Suddenly Pennsylvania doesn't seem TOO terrible!
:lol:
Still a PITA though!
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
UPDATE!!!
Postby absolutsnwbrdr » Mon Apr 05, 2010 8:17 am
I got a call from the notary on Saturday morning.
Registration went through without a problem, and they have my official title and license plate ready for me to pick up!!
Thats 1 week and 2 days since my paperwork was sent to PennDOT.
(Notary and PennDOT both said it would take 4-6 weeks.)
:banana: :banana: :banana:
Thank you, PennDOT, for not completely sucking the life out of me*
*results probably not typical
8)
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby absolutsnwbrdr » Wed Feb 12, 2014 1:51 pm
FYI - its been 4 years since I built my first teardrop, and I'm about to build a new one based on the Northern Tool 5x8 kit. I've been calling some "enhanced inspection" stations around my area (I moved from York to Hanover) and they all want anywhere from $150-250.
Except for this one that I've found in South-Central PA. There may be others, but I quit searching. I highly doubt you'll find cheaper!
Its the same place I used 4 years ago, and he's still only charging $50 +tax
Neiman's Garage
Dover, PA
(717) 292-2101
On my website, I have the instructions posted above as well as the instructions to register in Maine as a non-resident: http://www.zkaylordesigns.com/register_pa.html
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby mgb4tim » Wed Feb 12, 2014 3:06 pm
2 years ago, I took mine to a local RV center with the certificates and a weight slip ($8) from a local quarry. They did the photos, paperwork, and it was about $150. Technically, you're supposed to trailer the trailer since it's not registered. A couple weeks later came the state-issued VIN plate and a license plate.
mgb4tim
Postby absolutsnwbrdr » Wed Feb 12, 2014 3:10 pm
Nice. $150 for the inspection and registration and notary fees sounds pretty reasonable. Would you mind sharing where you went to? Someone near you might be struggling to find a place with a reasonable place.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby mgb4tim » Wed Feb 12, 2014 3:12 pm
It was Miley's in Carnegie, PA- SW of Pittsburgh. http://miley.com/. They did charge me a little extra to replace the s-hooks with a pair threaded closing link for the safety chains.
mgb4tim
Postby absolutsnwbrdr » Wed Feb 12, 2014 3:17 pm
Thats still a pretty good price though, especially for a one-stop shop.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
